Flip ColourCycle Direction?
I need a ColourCycle blade style that goes in the opposite direction to normal when the blade is lit. I seem to recall reading somewhere that you can change the direction of it, but I can’t remember how.
Blade setup is six pixels divided into two subblades. The first blade has five pixels and the second one pixel.
I tried flipping it at the blade array:
SubBlade (3, 0, WS281XBladePtr<5, bladePin etc.
but it didn’t work.
This is my blade style:
StylePtr<Layers<ColorCycle<ColorChange<TrInstant,
Rgb<180,255,255>,Rgb<185,212,212>,GhostWhite,Blue,Cornsilk,Azure,White,Red,FloralWhite,LightYellow,SeaShell,Green>
,0,1,ColorChange<TrInstant,
,25,160,800>,InOutHelperL<InOutFuncX<Int<300>,Int<800>>,Cylon<ColorChange<TrInstant,
,10,15,Black,0,0,1>>>>(),
I’m sure the answer is really simple - I just can’t remember what it is! LOL!
Advice welcome.
Thanks in advance.
:slight_smile:
Wrap it in below, this inverts the style contained within it. If you want other effects to also invert include them in a Layers<> within.
Remap<InvertF<RampF<>>,style code>
Or if you want ALL styles for that blade to reverse use:
A legend as always Fernando! Thanks you so much - that did the trick perfectly!
:smiley: :muscle: :ok_hand:
Much appreciated.
:pray:
Seems like negative speeds should also work, but it doesn’t seem like it does.
Maybe I should fix that…
