Extendable and Retractable Spinning Lightsaber Proffie Control
Also I’m having trouble finding where in the code to turn off swing sounds. Looking to turn off both swing and smoothswing. You mentioned the font configuration, is that a separate configuration file?
I did a quick read. It might work, although I’m not entirely sure what timer it uses.
The easy thing would be to just delete the swing sounds from the font.
Tried it, it also doesn’t work for some reason. Ended up moving away from servos towards a simpler mechanical solution for this project, just letting people know in case anyone else tries to control servos with Proffie
Oh got it, thanks!
Maybe this weekend I can have a look at the servo output in a logic analyzer and see if it looks reasonable. Maybe add some code to limit it to 1000-1500 us by default.
Ok, so I changed ServoBladePtr so that it generates 1-2ms pulses (black=1ms white=2ms).
Not sure if you still need/want this, but if you do, try out the latest github master.
Oh thanks! Using a different mechanical solution now, but might try this out down the line.
Thanks again for all your help with the code!!! I really appreciate it. Here’s the finished V2 version: https://youtu.be/_d7abTbiGFs?si=vo5D1wVz0Kioxnoc
I think it would have been great for the Proffie community if you had named in your video the “micro-controller” of choice as a ProffieBoard.
Super cool, great work! Thanks for sharing!
Ah true! I mentioned it in the first video but forgot to in this one.
Thank you!
