Error reading config
Arduino: 1.8.3 (Windows 10), Board: “Proffieboard V2, Serial + Mass Storage + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code”
In file included from D:\Lightsaber stuff\ProffieOS-v7.8\ProffieOS\ProffieOS.ino:614:
sketch\config/nigger_config.h:98:2: error: expected ‘}’ before ‘;’ token
98 | };
sketch\config/nigger_config.h:33:20: note: to match this ‘{’
33 | Preset presets[] = {
sketch\config/nigger_config.h:98:2: error: too many initializers for ‘Preset’
98 | };
Here’s my config:
saber_config.h (63.1 KB)
Unfortunately, the compiler is not super helpful here. All it’s telling you is that one of your prestes have to many things in it. (A preset is a list of “things” separated by commas.) It would be nice it would say which preset has the problem, but it doesn’t do that.
Since I’m on vacation in Japan right now, and it wasn’t obvious to me which preset has the problem, I’m going to tell you how to figure it out instead of figuring out for you:
The idea is to temporarily comment out some presets. If the one that has the problem is commented out, then it should start compiling.
An easy way to do that is to add #if 0 and #endif somewhere and see if it works.
For instance, to comment out the first preset only, it would look like this:
#if 0
   { "Bank01;common", "tracks/TFA_Battle.wav",
    StylePtr<InOutHelper<Blast<LocalizedClash<Lockup<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<Mix<SwingSpeed<600>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,300>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<0,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,StyleFire<BrownNoiseFlicker<Red,Rgb<25,0,0>,300>,Rgb<128,0,0>,0,8,FireConfig<10,1200,1>,FireConfig<0,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>>,StyleFire<Red,Rgb<150,150,150>,0,6>,TrInstant,TrSmoothFade<800>,EFFECT_IGNITION>,Mix<Bump<Int<32768>,Int<16000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,RandomPerLEDFlicker<OrangeRed,White>>,TrConcat<TrWipeIn<600>,Mix<Bump<Int<32768>,Int<16000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,RandomPerLEDFlicker<Orange,White>>,TrWipe<600>>,TrInstant,EFFECT_STAB>,BrownNoiseFlicker<White,Red,400>,TrInstant,TrSmoothFade<200>,EFFECT_LOCKUP_BEGIN>,Mix<Bump<Int<32768>,Int<10000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,White>,TrInstant,TrFade<200>,EFFECT_DRAG_BEGIN>,Mix<Bump<Int<32768>,Int<10000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,White>,TrInstant,TrFade<300>,EFFECT_DRAG_END>,Black,TrConcat<TrInstant,HumpFlicker<White,BrownNoiseFlicker<Red,Rgb<25,0,0>,400>,40>,TrColorCycle<600>>,TrInstant,EFFECT_RETRACTION>,Mix<Bump<Int<0>,Int<44000>>,Mix<Bump<Int<32768>,Int<44000>>,TransitionEffect<Red,White,TrInstant,TrFade<300>,EFFECT_LOCKUP_END>,Stripes<1000,-1500,Red,BrownNoiseFlicker<White,Red,300>>>,Stripes<1000,1500,Red,BrownNoiseFlicker<White,Red,300>>>,TrInstant,TrSmoothFade<800>,EFFECT_LOCKUP_END>,Pulsing<Gradient<BrownNoiseFlicker<Red,Rgb<25,0,0>,400>,BrownNoiseFlicker<White,Strobe<Blue,White,50,1>,100>>,Gradient<BrownNoiseFlicker<White,Strobe<Blue,White,50,1>,100>,BrownNoiseFlicker<Red,Rgb<25,0,0>,400>>,3500>,RandomPerLEDFlicker<BrownNoiseFlicker<Red,Rgb<25,0,0>,400>,White>,Bump<Int<16000>,Int<16000>>,Bump<Int<32768>,Int<10000>>>,White>,White>,150,300,Black>>()},
   { "Bank02;common", "tracks/FinalSteps.wav",
If the error is in the first preset, then it should start to compile, but that’s probably not the problem, so move the #endif down to somewhere in the middle, then try again. If it compiles, move it up, if it doesn’t move it down. Continue until you figure out which preset has a problem.
