I’ll have to split it up, because it’s longer than 100,000 characters:
// ProffieOS7 Config File
#define NUM_BLADES 4
const unsigned int maxLedsPerStrip = 155;
#define VOLUME 2550
#define CLASH_THRESHOLD_G 4.5
#define AUDIO_CLASH_SUPPRESSION_LEVEL 5
#define ENABLE_SSD1306
#define OLED_FLIP_180
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define BLADE_DETECT_PIN 17
#define SAVE_PRESET
#define FETT263_ENABLE_SPIN_MODE
#define FETT263_BM_CLASH_DETECT 8
#define FETT263_FORCE_PUSH
#define FETT263_TWIST_ON
//#define KEEP_SAVEFILES_WHEN_PROGRAMMING
#define FETT263_DISABLE_MULTI_BLAST
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
//#include "../props/saber_sabertrio_buttons.h"
Preset blade[] = {
{ "1-Magnet;common", "common/tracks/venus.wav",
StylePtr<Layers<
AudioFlicker<StripesX<Sin<Int<4>,Int<3000>,Int<6000>>,Scale<TwistAngle<>,Int<-50>,Int<-100>>,StripesX<Sin<Int<3>,Int<1000>,Int<3000>>,Scale<TwistAngle<>,Int<25>,Int<80>>,Pulsing<RotateColorsX<Variation,Rgb16<0,65535,52226>>,RotateColorsX<Variation,Rgb16<0,33908,20693>>,3000>,Mix<Sin<Int<2>>,RotateColorsX<Variation,Rgb<0,63,200>>,RotateColorsX<Variation,Rgb<0,7,8>>>>,RotateColorsX<Variation,Rgb<0,39,40>>,Pulsing<RotateColorsX<Variation,Rgb<0,36,30>>,StripesX<Sin<Int<2>,Int<2000>,Int<4000>>,Sin<Int<2>,Int<25>,Int<75>>,Mix<Sin<Int<4>>,RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Rgb<50,130,255>>>,RotateColorsX<Variation,Rgb<0,70,56>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<0,40,128>>,RotateColorsX<Variation,Rgb<0,38,30>>,3000>>,AlphaL<StripesX<Sin<Int<8>,Int<3000>,Int<6000>>,Scale<TwistAngle<>,Int<60>,Int<140>>,StripesX<Sin<Int<6>,Int<1000>,Int<3000>>,Scale<TwistAngle<>,Int<-25>,Int<-80>>,Pulsing<Mix<Sin<Int<4>>,RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Rgb<50,130,255>>>,RotateColorsX<Variation,Rgb<0,12,14>>,4000>,Mix<Sin<Int<2>>,RotateColorsX<Variation,Rgb<50,130,255>>,Black>>,RotateColorsX<Variation,Rgb<0,39,40>>,Pulsing<RotateColorsX<Variation,Rgb<0,26,40>>,StripesX<Sin<Int<2>,Int<2000>,Int<4000>>,Sin<Int<2>,Int<-25>,Int<-75>>,Mix<Sin<Int<4>>,RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Rgb16<1899,49276,65535>>>,RotateColorsX<Variation,Rgb<0,30,96>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<0,40,128>>,RotateColorsX<Variation,Rgb<0,16,50>>,3000>>,Int<10000>>>,
//Blue audioflicker lava lamp
AlphaL<AudioFlickerL<AlphaL<Mix<Trigger<EFFECT_FORCE,Int<4000>,Int<3800>,Int<200>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<33124,0,65535>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb16<43654,0,65535>>,RotateColorsX<Variation,Rgb16<9500,0,14386>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb16<0,65535,52226>>,RotateColorsX<Int<4000>,RotateColorsX<Variation,DeepSkyBlue>>>,RotateColorsX<Variation,Rgb16<43654,0,65535>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>>,SwingSpeed<450>>,
//Unstable, audio responsive swing. Force effect triggers a brief "charge up" effect while swinging which works well with the overcharged smooth swing
LockupTrL<Layers<
AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup
//Responsive lightning block
AlphaL<RotateColorsX<Variation,Rgb16<11366,0,65535>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1000>,Int<4000>>,Int<-4000>>>,
//Sparking emitter flare
ResponsiveStabL<Orange>,
//Responsive stab
ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Responsive clash
TransitionEffectL<TrConcat<TrFade<1040>,RotateColorsX<Variation,Rgb16<2521,681,18076>>,TrInstant,RotateColorsX<Variation,Rgb16<0,65535,52226>>,TrFade<550>>,EFFECT_IGNITION>,
//Charge up ignition effect
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb16<40546,3350,65535>>>,TrFade<1000>>,EFFECT_RETRACTION>,
//Purple retraction
//Drag
LockupTrL<AlphaL<Mix<TwistAngle<>,Orange,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
//Responsive melt
InOutTrL<TrColorCycle<1040,5500,2000>,TrWipeInSparkTip<White,875>>,
//Color cycle ignition, spark tip retraction
//InOutTrL<TrWipeInSparkTip<White,1040>,TrWipeInSparkTip<White,875>>,
//Alternate spark tip in ignition and retraction
//TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Orange,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,
//TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Orange,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_NEWFONT>,
//Optional/alternate passive battery monitor, on boot (1st line) or font change (2nd line) you will get a visual indicator at the emitter of your current battery level. This also works without a blade if you have a lit emitter or blade plug. Green is Full, Orange is Low (the color will blend from Green to Orange as the battery is depleted), the indicator will fade out after 3000 ms and not display again until poweOrange down and back up or fonts change.
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Orange,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Orange,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>
//On demand battery level, if using fett263's prop file Hold AUX and click PWR while OFF, the battery level is represented by the location on the blade; tip = full, hilt = low and color; green = full, yellow = half, Orange = low
StylePtr<Layers<
LockupTrL<Layers<
//Responsive lockup
//Responsive stab
//Responsive clash
//Purple retraction
//Drag
//Responsive melt
StylePtr<Layers<
LockupTrL<Layers<
//Responsive lockup
//Responsive stab
//Responsive clash
//Purple retraction
//Drag
//Responsive melt
StylePtr<Layers<
LockupTrL<Layers<
//Responsive lockup
//Responsive stab
//Responsive clash
//Purple retraction
//Drag
//Responsive melt
"magnet"
{ "2-Master;common", "common/tracks/mars.wav",
StylePtr<Layers<
Stripes<15000,-300,RotateColorsX<Variation,DarkOrange>,Pulsing<RotateColorsX<Variation,Rgb<255,111,30>>,RotateColorsX<Variation,DarkOrange>,800>,RotateColorsX<Variation,DarkOrange>>,
TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,DarkOrange>>,TrDelay<30000>,RotateColorsX<Variation,Orange>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<RotateColorsX<Variation,DarkOrange>,Scale<IsLessThan<SwingSpeed<300>,Int<13600>>,Scale<SwingSpeed<300>,Int<-19300>,Int<32768>>,Int<0>>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Orange,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,Red,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Orange>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
AlphaL<RotateColorsX<Variation,Snow>,Bump<Int<0>,Int<8000>>>,
ResponsiveStabL<Red>,
ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<230,180,80>>>,TrFade<1200>>,EFFECT_IGNITION>,
LockupTrL<AlphaL<Mix<TwistAngle<>,Red,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeSparkTip<White,300,40>,TrWipeIn<1400>>,
TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>>>(),
StylePtr<Layers<
LockupTrL<Layers<
StylePtr<Layers<
LockupTrL<Layers<
StylePtr<Layers<
LockupTrL<Layers<
TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>>>(), "master"
{ "3-Paradise;common", "common/tracks/venus.wav",
StylePtr<Layers<
StripesX<Sin<Int<12>,Int<13000>,Int<19000>>,Scale<SwingSpeed<100>,Int<75>,Int<125>>,StripesX<Sin<Int<10>,Int<3000>,Int<7000>>,Scale<SwingSpeed<100>,Int<75>,Int<100>>,Pulsing<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<50,115,65>>,1200>,Mix<SwingSpeed<200>,RotateColorsX<Variation,Rgb<0,120,0>>,Black>>,RotateColorsX<Variation,Rgb<0,60,0>>,Pulsing<RotateColorsX<Variation,Rgb<0,50,0>>,StripesX<Sin<Int<10>,Int<2000>,Int<3000>>,Sin<Int<10>,Int<75>,Int<100>>,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,96,0>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<0,128,0>>,RotateColorsX<Variation,Rgb<0,5,0>>,3000>>,
AlphaL<StyleFire<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,2,0>>,0,1,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<0,0,25>>,Int<10000>>,
//Green smoke blade
AlphaL<AudioFlickerL<RotateColorsX<Variation,Green>>,SwingSpeed<400>>,
//Green audioflicker swing
LockupTrL<Layers<
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrFade<2050>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup with endlock fadeout
//Responsive stab
ResponsiveBlastL<SparkleL<White,750,750>,Int<1100>,Int<500>,Int<10000>>,
//Sparky blast
ResponsiveBlastWaveL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
//Responsive Blast Wave
//EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
//Alternate Multi-blast, blaster reflect cycles through different responsive effects
ResponsiveClashL<SparkleL<White,500,750>,TrInstant,TrFade<1100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Sparky responsive clash
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<2500>>,EFFECT_IGNITION>,
//Unstable ignition effect
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<150,255,150>>>,TrFade<1239>>,EFFECT_RETRACTION>,
//Stable cooldown retraction
//Drag
//Responsive melt
InOutTrL<TrWipeInSparkTip<White,300>,TrJoinR<TrWipe<1100>,TrWipeIn<1100>>>,
//"Cable release" retraction, disconnects in the middle
//InOutTrL<TrWipeInSparkTip<White,300>,TrJoinR<TrWipe<675>,TrWipeIn<1100>>>,
//Alternate "cable release" retraction, top half wipes out much more quickly like the cable snaps away
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<White,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<1239>>,EFFECT_RETRACTION>,
//Bright emitter retraction click
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Orange,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Orange,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<1000>,Int<1000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Green>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Chartreuse>,Rgb16<0,21301,635>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Green>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Green>>>,RotateColorsX<Variation,Chartreuse>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-150>,Int<13500>>,Int<-4000>>>,TrDelay<3300>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<3471>,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Chartreuse>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<3750>>,Int<1500>,Int<4200>>,Int<-4000>>>,TrDelay<1250>,AlphaL<PulsingX<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Chartreuse>,Int<50>>,Bump<Int<0>,Int<7750>>>,TrBoing<400,4>,AlphaL<Pulsing<RotateColorsX<Variation,Chartreuse>,RotateColorsX<Variation,Green>,500>,Bump<Int<0>,Int<9750>>>,TrBoing<400,4>>,EFFECT_PREON>
//Wind-up preon
StylePtr<Layers<
//Green smoke blade
LockupTrL<Layers<
//Responsive stab
//Sparky blast
//Responsive clash
//Drag
//Responsive melt
//Wind-up preon
StylePtr<Layers<
//Green smoke blade
LockupTrL<Layers<
//Responsive stab
//Sparky blast
//Responsive clash
//Drag
//Responsive melt
//Wind-up preon
StylePtr<Layers<
//Green smoke blade
LockupTrL<Layers<
//Responsive stab
//Sparky blast
//Responsive clash
//Drag
//Responsive melt
//Wind-up preon
>>(), "paradise"
{ "4-SteelandFire;common", "common/tracks/venus.wav",
StylePtr<Layers<
//Base Fett263 Magenta Audioflicker
AudioFlicker<RotateColorsX<Variation,Magenta>,RotateColorsX<Variation,Rgb<95,0,95>>>,
//Deep Pink HumpFlicker Swing Effect
AlphaL<HumpFlicker<RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Rgb<105,0,210>>,50>,SwingSpeed<375>>,
//Fett263 Responsive Intensity Lockup with Fizzle Endlock
TrConcat<TrInstant,White,TrFade<600>,BrownNoiseFlicker<RotateColorsX<Variation,DeepPink>,Black,300>,TrFade<500>,AudioFlickerL<BrownNoiseFlicker<RotateColorsX<Variation,Rgb<105,0,210>>,Black,300>>,TrFade<850>>,SaberBase::LOCKUP_NORMAL>,
//Responsive Stab
//Fett263 Real Clash
//Unstable HumpFlicker Ignition Effect
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Magenta>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,95>>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<1250>,HumpFlicker<RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Magenta>,50>,TrFade<1250>,AudioFlicker<RotateColorsX<Variation,Magenta>,RotateColorsX<Variation,Rgb<95,0,95>>>,TrFade<700>,AudioFlicker<RotateColorsX<Variation,Rgb<105,0,210>>,RotateColorsX<Variation,Rgb<58,0,105>>>,TrFade<300>,HumpFlicker<RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Rgb<105,0,210>>,50>,TrFade<750>>,EFFECT_IGNITION>,
//Fett263 Bright HumpFlicker retraction Effect
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<195,60,225>>,40>,TrFadeX<WavLen<EFFECT_RETRACTION>>>,EFFECT_RETRACTION>,
//Fett263 Intensity Drag
LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,Orange,DarkOrange>,Mix<TwistAngle<>,Orange,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<6000>>>,TrConcat<TrWipeIn<100>,AlphaL<Orange,SmoothStep<Int<29000>,Int<8000>>>,TrExtend<2000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Orange,Orange>,SmoothStep<Int<29000>,Int<8000>>>,TrFade<3000>>,TrFade<250>,SaberBase::LOCKUP_MELT>,
//White spark tip ignition and retraction
InOutTrL<TrJoin<TrWipeX<Percentage<WavLen<EFFECT_IGNITION>,4>>,TrWaveX<White,Percentage<WavLen<EFFECT_IGNITION>,15>,Int<400>,Percentage<WavLen<EFFECT_IGNITION>,4>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrWaveX<White,Percentage<WavLen<EFFECT_RETRACTION>,200>,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
//Clicky retraction "post off" effect
TransitionEffectL<TrConcat<TrDelayX<WavLen<EFFECT_RETRACTION>>,AlphaL<Pulsing<Rgb<120,120,165>,Rgb<50,50,80>,40>,Bump<Int<0>,Int<9000>>>,TrDelayX<Percentage<WavLen<EFFECT_POSTOFF>,50>>>,EFFECT_RETRACTION>,
//Fett263 optional/alternate Passive Battery Monitor: on boot (1st line) or font change (2nd line) you will get a visual indicator at the emitter of your current battery level. This also works without a blade if you have a lit emitter or blade plug. Green is Full, Orange is Low (the color will blend from Green to Orange as the battery is depleted), the indicator will fade out after 3000 ms and not display again until poweOrange down and back up or fonts change.
//Fett263 On-Demand Battery Level: if using Fett263's prop file Hold AUX and click PWR while OFF, the battery level is represented by the location on the blade; tip = full, hilt = low and color; green = full, yellow = half, Orange = low
StylePtr<Layers<
//Responsive Stab
StylePtr<Layers<
//Responsive Stab
StylePtr<Layers<
//Responsive Stab
"steel and fire"
