Deep Sleep
I think I made progress of a sort. I’m not sure what I did differently to illicit this result but I’m now getting 3.3v measured between LED6 and 3.3v pads. However, whenever I have the negative lead of the BT909 connected to LED6, the speaker plays a constant tone and the saber is unresponsive to button presses or gestures. Moving the negative lead to the negative battery terminal makes the saber responsive again with no constant tone but, of course, the BT909 stays on at all times in this condition.
I could use some more help on this one.
Is anyone able to provide additional support here? I’m at a loss.
I’m at a bit of a loss. Here’s the checklist for what it needs, at least. I’m sure you’ve done all this but it can’t hurt.
  • #define ENABLE_SERIAL and #define IDLE_OFF_TIME 60 * 10 * 1000 in config_top
  • StylePtr<Blue>(), as the second blade style in each preset
  • SimpleBladePtr<CH3LED, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>(), as the second blade in the config
  • BT voltage to 3.3, BT negative to LED 6, TX on proffie to RX on BT, and RX on Proffie to TX on BT. Obviously make sure you’re using the new pins as they’ve changed locations from 2.2 to 3.9.
@profezzorn is it possible that there is a better style to use than StylePtr<Blue>(),cause that’s the only thing I can think of considering it works when his primary blade is on. @Upquark maybe post your entire config file here?
That’s all I got.
Thanks for the checklist. I went through everything and confirmed each one is correct. I’m beginning to suspect this is one only @profezzorn can answer unless there’s something obviously wrong with my config. See full config below.
// ProffieOS7 Config File
#define NUM_BLADES 2
#define NUM_BUTTONS 1
#define EXTRA_COLOR_BUFFER_SPACE 70
#define VOLUME 2000
#define CLASH_THRESHOLD_G 1.5
#define AUDIO_CLASH_SUPPRESSION_LEVEL 4
#define PROFFIEOS_ACCELEROMETER_RANGE 16
#define PROFFIEOS_MOTION_FREQUENCY 1600
#define KILL_OLD_PLAYERS
#define SAVE_PRESET
#define DISABLE_TALKIE
#define FETT263_MAX_CLASH 16
#define FETT263_SPIN_MODE
#define FETT263_USE_BC_MELT_STAB
#define FETT263_LOCKUP_DELAY 500
#define FETT263_THRUST_ON
#define FETT263_FORCE_PUSH_LENGTH 10
{ "Protostar;common", "common/tracks/venus.wav",
	StylePtr<Layers<
  //Base Fett263 Dark Orange Audioflicker
  AudioFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<128,34,0>>>,
  //Unstable Orange-Red Audioflicker Swing Effect
  AlphaL<AudioFlicker<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,Black,300>,RotateColorsX<Variation,Orange>>,SwingSpeed<285>>,
  //Fett263 Bright Ripple Hard Swing
  AlphaL<Stripes<2000,-3250,RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb<60,36,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,17,0>>,Black,800>>,Scale<IsLessThan<SwingSpeed<675>,Int<13600>>,Scale<SwingSpeed<675>,Int<-19300>,Int<32768>>,Int<0>>>,
  //Fett263 Bright Sparking Emitter Flare
  AlphaL<RotateColorsX<Variation,Rgb16<65535,52226,0>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1500>,Int<4500>>,Int<-6000>>>,
  //Fett263 Responsive Intensity Lockup
  TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<1950>>,SaberBase::LOCKUP_NORMAL>,
  //Responsive Stab
  //Fett263 Real Clash
  //Fett263 White Unstable Ignition Effect
  TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-2500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<2400>>,EFFECT_IGNITION>,
  //Bright Retraction Effect
  TransitionEffectL<TrConcat<TrFadeX<WavLen<EFFECT_RETRACTION>>,AudioFlickerL<RotateColorsX<Variation,Rgb16<65535,52226,0>>>,TrInstant>,EFFECT_RETRACTION>,
  //Fett263 Intensity Drag
  //Fett263 Dual Mode White Spark Tip Ignition and Retraction - Hold above horizontal for fast ignition or below horizontal for slow ignition.
  InOutTrL<TrJoin<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,5>,Percentage<WavLen<EFFECT_IGNITION>,50>>>,TrWaveX<White,Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,15>,Percentage<WavLen<EFFECT_IGNITION>,75>>,Int<400>,Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,5>,Percentage<WavLen<EFFECT_IGNITION>,50>>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrWaveX<White,Percentage<WavLen<EFFECT_RETRACTION>,200>,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
  //Audio responsive charge-up preon effect
  TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Percentage<WavLen<EFFECT_PREON>,33>,Percentage<WavLen<EFFECT_PREON>,34>,Percentage<WavLen<EFFECT_PREON>,33>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb16<65535,11439,0>>,RotateColorsX<Variation,Orange>,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb16<65535,52226,0>>>,RotateColorsX<Variation,Rgb<60,30,0>>,0,1,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,RandomPerLEDFlicker<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb16<14386,7000,0>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Orange>,100>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>,
  //Ripple-Out Preon Effect
  TransitionEffectL<TrConcat<TrDelayX<Percentage<WavLen<EFFECT_PREON>,65>>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb16<65535,52226,0>>,Int<115>,Int<375>,Int<250>,Int<0>>>,TrDelayX<Percentage<WavLen<EFFECT_PREON>,35>>>,EFFECT_PREON>
  StylePtr<Blue>(),
  "protostar"},
 CONFIGARRAY(presets) },
 /* Generated with Fett263 Config Helper v3.10 */
I don’t see anything wrong with the config.
Also…
This is really weird. The only difference between “LED6” and “BATT-” is that LED6 turns on and off and BATT- doesn’t. These crashes are happening with no changes in configuration, right?
One possible reason might be high resistance/cold solder joints maybe…
Correct! Just changing the location of the negative lead makes this happen.
I’ve double checked my solder joints and even tried resoldering but no luck.
What kind of capacitor did you add?
I didn’t have any SMD caps that were the right value so I just used a standard electrolytic (yes I got the polarity correct). It’s a 47uF 50v cap.
Hmm, I’m not enough of an EE to know if using an electrolyte makes a difference or not. Maybe try a larger cap? (220uF or something?)
Don’t have anything like that handy. I decided to just order some 100uF 0805 caps from Digikey. I’ll stack two if one isn’t enough. I’ll let you know in a few days if it works. Wish me luck.
Just got my tracking info from DigiKey and it’s going to be a little while before I get those caps…
In the meantime, any update on progress with deep sleep implementation @profezzorn? Anything I can do to help?
Where are you located @Upquark? I would be happy to send a couple your way.
I’m located near Portland, OR. Feel free to DM me! Thank you!
I can report that after receiving and installing a proper 0805 100uF to the board, the BT909 module is now “sleeping” as expected. This is with the positive lead connected to the 3.3v pad and negative to LED6. After 5min (per my config) it goes into idle and the module is no longer present on the scan list, indicating it is off. It resumes functionality after waking up the saber.
While this is a marked success and I deeply appreciate everyone’s help getting this working, I still feel strongly that deep sleep should be properly implemented to avoid this workaround. @profezzorn, has there been any forward momentum over the last couple weeks?
I’m afraid not. Starting a new job takes time and energy. It’s on my todo list to work on, but the todo list is getting somewhat length so I’m not sure when I’ll get to it I’m afraid.
With the greatest respect, I don’t feel it’s anyone’s place to “…feel strongly…” about anything in ProffieOS that they don’t like. Fredrik and others have created an incredible system spending countless hours of their time completely unpaid, and then made the results available to all of us for free. The code is readily available. If you want to copy it and spend a lifetime learning C++ to write deep sleep into it yourself, you are free to do so. Maybe it was just worded badly, but your post reads as if you feel that the author(s) of ProffieOS aren’t working hard enough. Such phrasing might be OK to Microsoft who get paid, but I don’t think it’s appropriate in respect of a fan-driven free product like ProffieOS.
Hope you don’t mind my mentioning it.
Sorry to start up an old thread, but I can’t seem to find any more recent info. Has deep sleep been implemented yet for the 3.9…?
I don’t think you missed anything. There aren’t any recent updates.
A while back, someone actually wrote a deep sleep implementation. It wasn’t complete enough to check into ProffieOS proper, and when measured, we found that it didn’t save much power, so the whole thing got put on hold, which is where we still are.
As I understand it, Proffieboard power consumption when Idle is already pretty low. Out of interest, how much lower could it feasibly go with a genuine deep sleep? Or put another way, how does idle power consumption with a Proffie compare with deep sleep power consumption on something like a CFX, GH3 or Xenopixel? Is there really much to be gained by making true deep sleep work?
Thanks for the update.
