/* copyright Fett263 (Crystal Chamber) OS7 Style
OS7.14 v3.24p
On Behavior: AudioFlicker (Single Color) [Color: BaseColorArg]
Off Behavior: Solid Color [Color: OffColorArg]
Base Color: BaseColorArg (0)
Effect Reaction: Static Color, IgnitionColorArg, Type: Emitter, Direction: Normal, Duration: 500, Consecutive Effects to Max: 6
Effect Reactions: Clash, Blast, Lockup, Lightning BlockIgnition Effect: Instant [Color: IgnitionColorArg]
PowerUp Effect: Power Flash [Color: IgnitionColorArg]
CoolDown Effect: Power Flash [Color: RetractionColorArg]
Lockup Effect: NoneLightning Block Effect:
0: crystalLBMulti0Shape - Begin: Responsive Impact - Style: Strobing AudioFlicker - End: Full Blade Absorb
[Color: LBColorArg]
Drag Effect: NoneMelt Effect: NoneClash Effect: Real Clash V1 Up [Color: ClashColorArg]
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,AlphaL<AlphaL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<Int<40000>,Int<-10000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<5461>>>,Int<500>,Int<10000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_RETRACTION>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,AlphaL<White,Int<0>>>,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,Blue>,50,1>,50,1>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,Blue>,50,1>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK,Int<1>>,InOutTrL<TrInstant,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,RgbArg<OFF_COLOR_ARG,Rgb<0,5,0>>>>>(),
So that’s the whole bladestyle, but not the whole preset.
That compiles fine as it is, so it’s something above or below that in your config code that’s not right.
Also FYI that style just does a glow, there’s no “voice activity” using NoisySoundLevel included like you wanted?
that one works i just dont know were to fit in the NoisySouldLevel
// ProffieOS7 Config File
#define NUM_BLADES 5
#define VOLUME 2300
#define CLASH_THRESHOLD_G 3
#define KILL_OLD_PLAYERS
#define MOTION_TIMEOUT 60 * 2 * 1000
#define FETT263_MAX_CLASH 14
#define FETT263_DISABLE_QUOTE_PLAYER
#define FETT263_TRACK_PLAYER_NO_PROMPTS
#define FETT263_TWIST_ON
#define SHARED_POWER_PINS
{ "ROTJFD;common", "ROTJFD/tracks/throne_duel.wav",
StylePtr<Red>(),
OS7.14 v3.24p
Off Behavior: Off [Color: OffColorArg]
[Color: LBColorArg]
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,AlphaL<AlphaL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<Int<40000>,Int<-10000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<5461>>>,Int<500>,Int<10000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_RETRACTION>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,AlphaL<White,Int<0>>>,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,Blue>,50,1>,50,1>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,Blue>,50,1>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK,Int<1>>,InOutTrL<TrInstant,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
OS7.14 v3.24p
[Color: LBColorArg]
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,AlphaL<AlphaL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<Int<40000>,Int<-10000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<5461>>>,Int<500>,Int<10000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_RETRACTION>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,AlphaL<White,Int<0>>>,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,Blue>,50,1>,50,1>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,Blue>,50,1>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK,Int<1>>,InOutTrL<TrInstant,TrWipeInX<BendTimePowX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Layers<
Rgb<20,0,0>,
AlphaL<Red,NoisySoundLevel>>>
StylePtr<Layers<Black,InOutTrL<TrInstant,TrInstant,TransitionLoop<Black,TrConcat<TrDelay<3000>,Red,TrBoing<2000,5>>>>>>(),
StylePtr<Layers<Green,InOutTrL<TrInstant,TrInstant,TransitionLoop<Green,TrConcat<TrBoing<3000,9>,Black,TrDelay<2000>>>>>>(),
"preset0"
WS281XBladePtr<1, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<1, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin7, -1, -1, -1>(),
SimpleBladePtr<CH2LED, NoLED, NoLED, NoLED, bladePowerPin8, -1, -1, -1>()
, CONFIGARRAY(presets) } ,
Button PowerButton(BUTTON_POWER, auxPin, "pow");
Button AuxButton(BUTTON_AUX, powerButtonPin, "aux");
this gets errors when I sub in your code, your right I’m missing a comma or bracket or something, I’m just not experienced enough to know where.
You just forgot a comma after the style’s closing >()
yea i would never have caught that. thank you so much!
