No resistor = infinite resistance.
Usually it comes up somewhere in the 150k range becasue of the limits of measurements.
So I see this is now a feature request on GitHub, which made me re-read the SubBlade Wiki page.
It says "Since you can't have two blade definitions for the same string, you must use NULL to make multiple SubBlades refer to the same string of pixels.
which sounds perfectly fine if you’re splitting up the LED strip itself. But the template takes a blade definition, and therefore in theory, couldn’t using a different one for a set of pixels NOT on the same strip work instead of NULL and using the blade definition from the previous call to SubBlade() ?
That may compile, but it’s not actually going to work.
