Try “Color Blend (Rotate)” and adjust the Blend Size and Speed to your liking.
@Fett263 is colorblend the same as color shift? I don’t an option with the color blend name…
No, Color Blend is a “Type” of Dual Phase blade in the Blade Builder. It’s listed in the dropdown.
found it lol, I was looking at the wrong place man I’m so sorry haha. My poor vision got the better of me lol
hello there Fett, I was wondering if there is a define to configure the amount of time it takes for the saber to ignite after pressing the power button. it seems that mine has a second delay between pressing the button and the saber turning on
Usually this is because the SD card is taking a bit of time to power on.
Maybe try a different SD card and see if that helps?
As profezzorn notes, it’s most likely your SD card. We’ve seen a lot of subpar SD cards ever since the pandemic. You can test your SD in Serial Monitor.
First remove this define
Then upload.
With your board connected to the computer go into Tools > Serial Monitor
Type
sdtest
Wait for results.
You want at least 1200kbps read speed and 12 simultaneous audio streams. If its less then your SD card isn’t sufficient and you’ll want to find a better one, but that can be tough as even long established cards see to be underperforming since the pandemic and subsequent shortages. I think manufacturers started taking shortcuts to catch back up.
GENERAL KENOBI. sorry i had to.
