Config manual?
Is there a preset config manual somewhere that describes what the various flags are and what they do? Right now I feel like I’m stabbing at the dark trying to figure out how to control various lighting effects. One in particular, the power down effect, I’d like to adjust the timing but can’t figure out how for a fairly complicated press I pulled from Greyscale Fonts:
 { "He-Man", "common/tracks/venus.wav", //5
	StylePtr<Layers<
  //Base Fett263 Dark Orange Audioflicker
  AudioFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<128,34,0>>>,
  //Unstable Orange-Red Audioflicker Swing Effect
  AlphaL<AudioFlicker<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,Black,300>,RotateColorsX<Variation,Orange>>,SwingSpeed<285>>,
  //Fett263 Bright Ripple Hard Swing
  AlphaL<Stripes<2000,-3250,RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb<60,36,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,17,0>>,Black,800>>,Scale<IsLessThan<SwingSpeed<675>,Int<13600>>,Scale<SwingSpeed<675>,Int<-19300>,Int<32768>>,Int<0>>>,
  //Fett263 Bright Sparking Emitter Flare
  AlphaL<RotateColorsX<Variation,Rgb16<65535,52226,0>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1500>,Int<4500>>,Int<-6000>>>,
  //Fett263 Responsive Intensity Lockup
  TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<1950>>,SaberBase::LOCKUP_NORMAL>,
  //Responsive Stab
  //Fett263 Real Clash
  //Fett263 White Unstable Ignition Effect
  TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-2500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<2400>>,EFFECT_IGNITION>,
  //Bright Retraction Effect
  TransitionEffectL<TrConcat<TrFadeX<WavLen<EFFECT_RETRACTION>>,AudioFlickerL<RotateColorsX<Variation,Rgb16<65535,52226,0>>>,TrInstant>,EFFECT_RETRACTION>,
  //Fett263 Intensity Drag
  //Fett263 Dual Mode White Spark Tip Ignition and Retraction - Hold above horizontal for fast ignition or below horizontal for slow ignition.
  InOutTrL<TrJoin<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,5>,Percentage<WavLen<EFFECT_IGNITION>,50>>>,TrWaveX<White,Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,15>,Percentage<WavLen<EFFECT_IGNITION>,75>>,Int<400>,Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,5>,Percentage<WavLen<EFFECT_IGNITION>,50>>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrWaveX<White,Percentage<WavLen<EFFECT_RETRACTION>,200>,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
  //Audio responsive charge-up preon effect
  TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Percentage<WavLen<EFFECT_PREON>,33>,Percentage<WavLen<EFFECT_PREON>,34>,Percentage<WavLen<EFFECT_PREON>,33>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb16<65535,11439,0>>,RotateColorsX<Variation,Orange>,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb16<65535,52226,0>>>,RotateColorsX<Variation,Rgb<60,30,0>>,0,1,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,RandomPerLEDFlicker<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb16<14386,7000,0>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Orange>,100>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>,
  //Ripple-Out Preon Effect
  TransitionEffectL<TrConcat<TrDelayX<Percentage<WavLen<EFFECT_PREON>,65>>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb16<65535,52226,0>>,Int<115>,Int<375>,Int<250>,Int<0>>>,TrDelayX<Percentage<WavLen<EFFECT_PREON>,35>>>,EFFECT_PREON>
  >>(), "he-man"},`
I think the short answer here is no, there isn’t a real good manual for how to construct styles.
There are some videos that might help I think, but no manuals.
For this specific task though, I assume you’ve tried putting the style in the style editor, finding the InoutTrL layer and go make changes there? (It’s linked from your post, so you can just click on the blue text and it will take you to the style editor.)
Oh wow thank you! i didn’t realize that. Thanks so much.
