Hello fellow saber enthusiasts! I’ve just finished construction of my first proffie saber, and installed proffieOS. It seems to be working fine with the default SD card contents. I added the Fett263 prop file and a number of gesture control options. I also added the Rogue One Vader font from Kyberphonic’s Father_v2 package with a style created using the Fett263 style editor. Once I did that, I received the below error when trying to upload to the proffie board. Any guidance would be much appreciated, since I’m new to proffie. Thanks in advance.
Here is the error message:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Proffieboard V2, Serial + Mass Storage + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\ProffieOS.ino:235:
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h: In member function 'virtual void LSM6DS3H::Loop()':
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\common\monitoring.h:82:48: error: 'TRACE_CATEGORY_TIMEOUT' was not declared in this scope; did you mean 'TRACE_CATEGORY_I2C'?
82 | #define TRACE_CATEGORY(CAT) TRACE_EXPAND_AGAIN(TRACE_CATEGORY_##CAT)
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\common\monitoring.h:81:34: note: in definition of macro 'TRACE_EXPAND_AGAIN'
81 | #define TRACE_EXPAND_AGAIN(CAT) (CAT)
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\common\monitoring.h:108:7: note: in expansion of macro 'TRACE_CATEGORY'
108 | if (TRACE_CATEGORY(CAT) & (TRACING_CATEGORIES)) \
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:191:4: note: in expansion of macro 'TRACE'
191 | TRACE(MOTION, "timeout");
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\config\MPP_25.h:29:24: error: expected ')' before numeric constant
29 | #define MOTION TIMEOUT 60 * 15 * 1000
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:191:10: note: in expansion of macro 'MOTION'
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\common\monitoring.h:81:33: note: to match this '('
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\common\monitoring.h:82:29: note: in expansion of macro 'TRACE_EXPAND_AGAIN'
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\common\monitoring.h:109:12: error: expected ')' before 'while'
109 | do { } while(0); \
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\common\monitoring.h:108:6: note: to match this '('
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h: In member function 'void LSM6DS3H::Poll()':
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:284:7: note: in expansion of macro 'TRACE'
284 | TRACE(MOTION, "nothing pending1");
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:284:13: note: in expansion of macro 'MOTION'
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h: In member function 'virtual void LSM6DS3H::RunLocked()':
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:292:5: note: in expansion of macro 'TRACE'
292 | TRACE(MOTION, "RunLocked");
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:292:11: note: in expansion of macro 'MOTION'
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:295:7: note: in expansion of macro 'TRACE'
295 | TRACE(MOTION, "nothing pending2");
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:295:13: note: in expansion of macro 'MOTION'
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:299:7: note: in expansion of macro 'TRACE'
299 | TRACE(MOTION, "notify fail");
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:299:13: note: in expansion of macro 'MOTION'
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:308:7: note: in expansion of macro 'TRACE'
308 | TRACE(MOTION, "transfer fail");
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:308:13: note: in expansion of macro 'MOTION'
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:311:5: note: in expansion of macro 'TRACE'
311 | TRACE(MOTION, "transferring...");
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:311:11: note: in expansion of macro 'MOTION'
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h: In member function 'void LSM6DS3H::DataReceived2()':
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:322:5: note: in expansion of macro 'TRACE'
322 | TRACE(MOTION, "Transfer done");
C:\Users\josia\Documents\Arduino\Proffie\ProffieOS-v7.8\ProffieOS\motion\lsm6ds3h.h:322:11: note: in expansion of macro 'MOTION'
And here is the config file I am using:
#define VOLUME 2200
#define CLASH_THRESHOLD_G 3.8
//Customized Options
#define FETT263_MAX_CLASH 16
#define FETT263_SAY_BATTERY_VOLTS
#define FETT263_TWIST_ON
#define FETT263_THRUST_ON
#define FETT263_SWING_ON
#define FETT263_SAY_COLOR_LLIST_CC
#define SAVE_STATE
//Rogue One Vader
{"R1;common", "common/tracks/hallwayscene.wav",
OS6.7 v4.021
Base Color: Rgb<255,0,0> (0)
Preon Effect: Disable
Melt Effect: Intensity Melt
Clash Effect: Real Clash V1
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,244,157>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,244,157>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,244,157>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<700>>,TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrInstant,EFFECT_PREON>>>(),
"Rogue"},
{ "TeensySF;common", "common/tracks/venus.wav",
{ "SmthJedi;common", "common/tracks/mars.wav",
{ "SmthGrey;common", "common/tracks/mercury.wav",
StyleFirePtr<RED, YELLOW>(), "fire"},
{ "SmthFuzz;common", "common/tracks/uranus.wav",
{ "RgueCmdr;common", "common/tracks/venus.wav",
StyleFirePtr<BLUE, CYAN>(), "blue fire"},
{ "TthCrstl;common", "common/tracks/mars.wav",
{ "TeensySF;common", "common/tracks/mercury.wav",
{ "SmthJedi;common", "common/tracks/uranus.wav",
{ "SmthGrey;common", "common/tracks/venus.wav",
{ "SmthFuzz;common", "common/tracks/mars.wav",
{ "RgueCmdr;common", "common/tracks/mercury.wav",
{ "TthCrstl;common", "common/tracks/uranus.wav",
&style_pov, "POV"},
{ 0, WS281XBladePtr<116, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
MOTION_TIMEOUT is missing the underscore.
Thanks so much for the help! I figured it was something simple like that. What I’m working on now is the battle mode clash vs. lockup thresholds. I’m trying to use the CLASH_THRESHOLD_G, FETT263_MAX_CLASH, and FETT263_BM_CLASH_DETECT defines to set up the “impact level zones” for clash or lockup. Are these the defines I should be using, and do you have any recommendations for reasonable values to use there?
CLASH_THRESHOLD_G is the main clash threshold, this will depend on your specific saber but 3.0 is a safe starting point
FETT263_MAX_CLASH is tied to Real Clash sounds, not Battle Mode info here: ProffieOS Documentation: ProffieOS6 "Real Clash" sounds in Fett263 Prop
FETT263_BM_CLASH_DETECT this is the threshold for clash vs. lockup in Battle Mode 2.0, 7 is a good starting point. That means a clash that is between CLASH_THRESHOLD_G and 7.0 will be treated as a normal clash in Battle Mode, any clash over 7.0 will trigger a lockup, but just as in Battle Mode 1.0, if you do a quick hit and pull away, it will run your begin and end lockup in quick succession to mimic a clash as well.
Note, if you need help with defines and set up for OS7, the config tool takes all of the guesswork out of it AND prevents typos and syntax errors
It describes all of the options and ranges and makes it easy to customize and set up your config. It will also generate a custom Button/Control list to print based on the selections you make.
Thanks for the info. I didn’t realize this tool existed. I figured out that that gesture lockup wasn’t being activated because I had the FETT263_TWIST_ON_NO_BM define in the config file, so it wasn’t ever entering battle mode.
