Compilation Error
Ive been having the same issue of
“fork/exec/Users/jasonduckenfield/Library/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/arm-none-eabi-g++: no such file or directory
Error compiling for board Proffieboard V2.”
I tried a couple different methods such as new cables, uninstalling and reinstalling. Im out of ideas. Im not even sure it even the error message means. I just need help because it only started a couple days ago and it has never happened before and ive put a whole bunch of blade styles on my saber already.
This is a different problem than the thread you posted in, so I moved it to a new thread. In general, when you’re seeking help, you almost always want to start a new thread.
This error means that Arduino is having a problem finding or executing the compiler needed to turn the text files into programs that the Proffieboard can run. These files are provided by the arduino-proffieboard plugin, so the solution is to re-install the arduino-proffieboard plugin.
