No problem! At least it’s not my hardware (or me going crazy), so that helps!
I have been trying to find the time to do some testing by eliminating things in the config until I didn’t have the error, but haven’t had time yet.
Thanks!
Thanks!
I figured it out… This line:
Should be:
SubBlade(8, 15, WS281XBladePtr<16, bladePin, Color8::GRB, PowerPINS<bladePowerPin1>>()), // b1 front green scanny thing
// ^-- note X
Apparently bad things happen when you mix these two things up…
Oh, interesting. I usually copy paste code, so I wonder where that even came from.
Thanks for chasing that down! I will try to do more testing on the display now.
WS2811BladePtr and WS281XBladePtr really shouldn’t be compatible this way. It would be way better if this generated a compiler error. I’m not sure if there is anything I can do to make that happen, but I will check.
Well, that fixed all the funkiness! The sound and pixels work as they should, but still no display.
show /tng/280x240/biocircuitry.pqf no longer works
Please post your latest config file and I’ll take a look.
Also, what does “displaystate” say now?
Here is my config now:
#define NUM_BLADES 4
#define VOLUME 2000
#define CLASH_THRESHOLD_G 1.0
#define ENABLE_SPIDISPLAY
#define ENABLE_DEVELOPER_COMMANDS
//EYESPI PBV3 function
//TCS data4 Chip Select
//DC Free3 Command Select
//MOSI Data3 Data
//SCK Free1 Clock
//Gnd GND power
//Lite Free2 Backlight control
//Vin SD_VDD power
{ "tng;common", "tracks/tng.wav",
StylePtr<Layers<Black,Cylon<Green,5,20,Red,5,20,1>>>(), //1
StylePtr<Layers<Black,Cylon<DeepSkyBlue,5,20,Red,5,20,1>>>(), //2
StylePtr<Layers<Black,Cylon<Green,5,20,Red,5,20,1>>>(), //3
StylePtr<Layers<Black,Cylon<Red,5,20,Red,5,20,1>>>(), //4
// StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), //5
// StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), //6
// StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), //7
// StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), //8
// StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), //9
// StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), //10
// StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), //11
// StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), //12
{ "Unstable;common", "tracks/KyloRen.wav",
StylePtr<Layers<Black,Sequence<Cyan,Black,100,37,0b1010101010101,0b111000111000111,0b100000000000000>>>(), //1
StylePtr<Layers<Black,Sequence<Red,Black,100,37,0b1010100011100,0b111000111000101,0b100000000000000>>>(), //2
{ 0,
SubBlade(8, 15, WS281XBladePtr<16, bladePin, Color8::GRB, PowerPINS<bladePowerPin2>>()), // test change
// SubBlade(8, 15, WS281XBladePtr<16, bladePin, Color8::GRB, PowerPINS<bladePowerPin1>>()), // b1 front green scanny thing
SubBlade(0, 3, NULL), // b2 big blue scanny thing
SubBlade(4, 5, NULL), // b3 side by side green
SubBlade(6, 7, NULL), // b4 up down red
// SubBlade(0, 2, WS281XBladePtr<14, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin2>>()), // b5 front 3 green
// SubBlade(3, 5, NULL), // b6 geo met bio
// SubBlade(6, 9, NULL), // b7 alpha beta gamma delta
// SubBlade(10, 10, NULL), // b8 front power red light
// SubBlade(11, 12, NULL), // b9 upper front green lights
// SubBlade(13, 13, NULL), // b10 upper front red light
// SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin4, -1, -1, -1>(), // b11 lower lights (two red leds)
// SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin3, -1, -1, -1>(), // b12 front dim lights (warm white)
CONFIGARRAY(presets) },
#ifdef CONFIG_BOTTOM
SPIDisplay_AdaFruit5206<3> display;
StandarColorDisplayController<280, 240> display_controller(&display);
“displaystate”:
Battery voltage: 4.15
to_send: 0
PCLK1: 40000000 PCLK2: 40000000
frame = 0 rownum_ = 0 layer = 0 base = 0 top = 0 next state: 520 buffered rows: 1
*** Layer 0 ***
Is that really the entire output of “displaystate” ?
What version of arduino-proffieboard are you using?
Your config file works with no modifications for me, and I can show the biocircuitry.pqf file successfully. Maybe some wire has come loose?
Maybe I didn’t grab it all. Here is another:
Welcome to ProffieOS $Id: ce12a06a1e236b5101ec60c950530a9a4719a74d $
I2C init..
Motion chip ... 106 found.
EVENT: Clash millis=1322
Amplifier off.
Unmounting SD Card.
to_send: 0
*** Layer 0 ***
STOP File:
play time: 9841ms POS: 0 EOF: 1 KBPS: 0.00 Bufsize: 0 next state: -2
frame drop fps:
*** Layer 1 ***
STOP File:
play time: 9842ms POS: 0 EOF: 1 KBPS: 0.00 Bufsize: 0 next state: -2
frame drop fps:
*** Layer 2 ***
STOP File:
frame drop fps:
Battery voltage: 4.12
I am using arduino 2.3.2, with plugin v4.6 experimental. Should I try the main channel v4.6?
I tried again, and now “show” works, but it doesn’t play any animations any other time. Did it play them for you? I must have something wrong with the scr and pqf files.
This shows no indication that it’s even trying to show something.
Usually when something fails, it’s trying to show something, but is stuck, and displaystate looks the same if you run it multiple times in a row.
4.6 is 4.6, regardless of which channel you get it from.
You could try an older version, but so far it seems like 4.6 has less bugs than earlier versions.
I didn’t try any scr files, just “show”.
Since “show” works, that basically means that your PQF file works.
Fixing problems with the display, and fixing problems with scr files are basically different things.
I did find the PM that had the biocircutry.pqf file, and it has a scr file in it. That file has the wrong name, and also lacks a newline at the end of the file.
Basically there are two helpful things you can do:
I did end up fixing the file naming earlier. I have had these files for the last couple rounds of testing:
/tng/280x240/boot.scr
/tng/280x240/font.scr
/tng/280x240/idle.scr
/tng/280x240/on.scr
Effects did find these files:
Found 280x240/idle.scr files: one unnumbered file in tng
Found 280x240/on.scr files: one unnumbered file in tng
Found 280x240/font.scr files: one unnumbered file in tng
Found 280x240/boot.scr files: one unnumbered file in tng
Found vmend.wav files: one unnumbered file in common
Found vmbegin.wav files: one unnumbered file in common
Found mnum.wav files: 1-20 in subdirs in common
Found mclick.wav files: one unnumbered file in common
Found ccchange.wav files: one unnumbered file in common
Found ccend.wav files: one unnumbered file in common
However show /tng/280x240/on.scr still displayed nothing.
I am not sure what this means. I looked again at the layer controller info and changed on.scr from:
file=biocircuitry.pqf
to:
layer
Now, show /tng/280x240/on.scr does show the pqf, however turning the saber “on” still does not display anything.
also, show /tng/280x240/on.scr seems pretty picky. Right on boot, it will display the pqf, but after that it will not display again.
I did a bit more testing. The display is working and displaying things, just not consistently. So i must have the syntax of the scr files off. I still don’t know all the ins and outs of them.
I still have the same four scr files, but I changed them all to refer to different pqf files so I can tell when they are working.
When I power it on, boot.scr does display. When I press power, the on.scr does not display. when I hit power again, idle.scr does display. When I cycle fonts, font.scr does not display, but the screen lights up briefly.
Here are the contents of the files:
boot.scr
file=logo.pqf
time=5000
layer
on.scr
file=spiralgalaxymw.pqf
restart
layer
idle.scr
restart
layer
font.scr
file=lcars_terminal.pqf
time=4500
layer
I assume I am messing something, can you help with direction?
While it’s possible that you’re missing something, this code is also new and not well tested, so it’s about 50/50 chance that I missed something.
I will be doing some testing on my side shortly.
If you could send me the files you’re using, that would be helpful.
Sent a pm.
Thanks!
Well, I’m going to have to upgrade that 50/50 to 100/100, finding lots of bugs… now I just have to fix them.
One thing though, your animation PQF files don’t seem to have a set frame rate, which means that once I fix the bugs, they will just show the first frame. How did you make these? Normally when you convert a movie with cpqf it automatically puts the frame rate in there.
I used the pqoi from the master on ubuntu.
./cpqoi somemovie.mp4 "pamscale -xysize 280 240" >animation.pqf
I didn’t do the pqoiml part, but now I see that’s is whats needed for framerate?
No, it’s supposed to figure out the frame rate and insert it when you do that.
I’ll take a look at that too.
do you have “ffprobe” installed on your ubuntu?
I don’t think so.
Edit - I did a search and it said its part of FFmpeg, which I do have. Can I verify if I do or do not have ffprobe?
