Charging a 3.9
Trying out a 3.9 board for the first time.
If I include a barrel recharge port, does the kill key work as it normally would?
Can I than chose to charge from the port or the micro usb on the board?
Thanks!
Yes. You kill battery power to a BATT pad on the board but charge the battery directly using the RCP port.
You can use the USB port on the Proffieboard as long as there’s a connection to the battery (no kill key in situation above)
