Before I say anything OS6 is amazing and so far, I find it so much easier and cooler than OS5… Anyway, I uploaded my config and every “define” I’ve put in so far has worked except for edit mode. I’ve put the required defines in my config and I’ve also put the common folder in my SD card, but with no luck. I’ve attached my pastebin, a video for proof, and a picture of what is in my SD card.
pastebin: edit mode help - Pastebin.com
video: edit mode help. - YouTube
Are the voice pack sounds in your common folder?
http://fredrik.hubbe.net/lightsaber/sound/
Actually I checked your video, I think you’re doing the clicks wrong, it would have said “Error in Font directory” if the sounds were missing.
For Double click and hold you should click once, then hold second, it looks like you’re clicking twice and holding 3rd.
Exit Edit Mode - Hold AUX (or rotate to "Exit") while in Main Menu
"Edit Color" Additional Control
"Color List" and "Adjust Color Hue" Zoom Mode = Hold PWR while turning to Zoom color in, release to save
---------- 1 Button Controls (based on SA22C prop) ----------
NOTE:
Click = do short click (so Double Click is two short clicks in quick succession)
Long Click = hold button for 1 second and release
Hold = hold button down
Click and Hold = hold on Xth click (so Double Click and Hold would be click twice and hold on second)
Click + Long Click = do X clicks then do long click (so Double Click + Long Click would be click twice then do a long click)
Standard Controls While Blade is OFF
Turn On / Ignite Saber* = Click PWR
*If FETT263_MOTION_WAKE_POWER_BUTTON defined first Click will Wake up motion detection and boot sound will play
NEW Control! Turn On / Ignite Saber (Muted) = Click + Long Click PWR
NEW Control! Start / Stop Tracks = Double Click PWR (pointing straight up)
NEW! Track Player* = Double Click PWR (parallel or down)
*if only default track exists in current preset, track will "Loop"
Turn Right (Stepped) = Next Track
Ok, just had to confirm, see my 2nd reply above I think you’re clicking too many times.
Oh, I feel so dumb that’s what it meant. Sorry to bother you so late and thank you again!.. you are the Sith Master to us all!
No problem, always better to ask when you’re unsure. Enjoy.
