you could also have used WORDS_WITH_UNDERSCORE, but I understand. Nobody likes to be SHOUTED at.
Right, so the “talkie_” & “_15” parts from “talkie_something_15” don’t “do” anything, they are just your naming convention.
Ok, but if you compare the content of (for example):
const unsigned char spLOWBATTERY[] = {0x80,0x02,0xEC,0x4F,0x3D,0x5D,0x2E,0x8A,0xF1,0x1C,0x96,0x0E,0x59,0x22,0x66,0x7E,0x9D,0x3B,0x2D,0x99,0xD8,0x8A,0x49,0x8E,0x8E,0x94,0xC2,0x60,0x26,0x38,0x47,0x70,0x0B,0x63,0x6C,0x93,0x19,0x23,0x25,0x8C,0xA9,0x8C,0x67,0x8C,0xA4,0x30,0xA4,0x52,0xD9,0x34,0x12,0x02,0x5F,0xCA,0x64,0xCA,0x48,0x08,0x6C,0x2D,0x93,0xC9,0x20,0x2E,0x30,0x3D,0x55,0x36,0x8B,0xB8,0xC0,0x0E,0x17,0x9D,0x0E,0x62,0x02,0x33,0x9D,0x6D,0x2B,0xB4,0x0A,0xF5,0x0C,0xD6,0xAD,0xC0,0x22,0x32,0x3D,0x0C,0xBB,0x07,0xA3,0x84,0xE5,0x34,0x8C,0x8A,0x04,0xA0,0x22,0x17,0xC2,0x3D,0x2D,0x50,0x89,0x62,0xF2,0xC8,0xF4,0xC0,0x2D,0x8A,0x59,0x3B,0x32,0xC5,0x8C,0x28,0x25,0x6D,0xEF,0x30,0x33,0xA2,0x9C,0xB5,0xA2,0xC3,0x74,0x8B,0x52,0x96,0xCE,0x0A,0x29,0x25,0x8A,0x49,0x33,0x33,0xC4,0xB8,0x24,0x6B,0x2D,0x1E,0x0F,0xE5,0x92,0x18,0x29,0x6D,0xCC,0x94,0x49,0x53,0xC6,0xD6,0xD1,0x88,0x2A,0x4B,0x05,0x47,0x5B,0x4A,0xAA,0x2C,0x66,0x1C,0x6B,0xA9,0x20,0xF2,0x98,0x70,0xAC,0xA5,0xB0,0x28,0x62,0xC0,0x89,0x96,0x20,0xAA,0x4C,0x96,0x32,0x47,0x03,0xAB,0x32,0x19,0xF2,0x5E,0x35,0xCC,0xAA,0xA8,0xB0,0xBB,0x55,0x28,0xA9,0xA2,0xC4,0xC9,0x62,0x6A,0xA8,0xCC,0x02,0x36,0x9A,0x90,0xA1,0x32,0x70,0xDC,0x48,0x62,0x06,0x00,0xF0};
const unsigned char talkie_low_battery_15[] = {0x00,0x80,0x02,0x94,0x87,0xBD,0x5C,0x0E,0x8A,0xD1,0x6A,0xD6,0x72,0xD9,0x24,0x21,0xF9,0x8C,0x33,0x2D,0xB1,0x98,0xDB,0x0D,0xE9,0x8C,0xC4,0x62,0x69,0xD6,0x68,0x47,0xB0,0x8B,0x02,0xAD,0x36,0xAD,0xC4,0x21,0x0C,0x7A,0x92,0x63,0x4C,0xA7,0x30,0x86,0x36,0xE9,0x11,0x9C,0xC2,0x18,0xDB,0x64,0xC6,0x48,0x0A,0x53,0x2A,0xE3,0x99,0x20,0x29,0x8C,0x25,0x55,0xB6,0x8D,0x84,0x20,0xA4,0x36,0xD9,0x34,0x12,0x02,0x9F,0xCB,0xB9,0xD3,0x88,0x0B,0x7C,0x4D,0x95,0x29,0xA3,0x2E,0xB0,0x2D,0x4D,0x26,0x8D,0x98,0xC0,0xD4,0x36,0x9E,0x08,0x62,0x02,0xD3,0x53,0x64,0x33,0x88,0x09,0xEC,0x08,0x91,0xA9,0x22,0x26,0xB0,0xD3,0x44,0xA7,0x83,0xA8,0xC0,0x4E,0x67,0xDB,0x0A,0xAC,0x42,0x3D,0x82,0xED,0x32,0xB4,0x08,0xD5,0x0C,0xD6,0xAD,0xC0,0x2C,0xD2,0xC3,0x95,0xA6,0x0B,0x93,0xD8,0xD6,0x34,0xA8,0x1E,0x8D,0x12,0x9A,0xCB,0xD9,0xD3,0x32,0x00,0x00,0x11,0x83,0x71,0x95,0xF4,0xC8,0x26,0x72,0x21,0xDC,0xD3,0x02,0xA7,0x28,0x26,0xF7,0xC8,0x08,0x5C,0xA2,0x98,0xB5,0x22,0xD2,0x48,0x89,0x62,0xD6,0x8E,0x4C,0xB1,0x25,0x4A,0x59,0xDB,0x3B,0xCC,0xB4,0x28,0x27,0x2D,0xEF,0x30,0xD3,0xA2,0x9C,0xB5,0xA2,0xC3,0x4C,0x89,0x52,0x96,0x8A,0x0E,0xD1,0x25,0x4A,0x45,0x3A,0x33,0xA4,0xA4,0x28,0x66,0xCD,0x8A,0x10,0xEA,0xE2,0x14,0xB5,0xAC,0x43,0xB4,0x49,0x8A,0x92,0x96,0xB6,0x48,0x2E,0x89,0x41,0xC2,0x56,0x4D,0x9B,0x24,0x46,0x2A,0x1D,0x97,0xA4,0xD2,0x94,0xB1,0x6D,0xD4,0xA2,0x4A,0x53,0xC1,0x96,0xD1,0x0A,0x22,0x4B,0x05,0x47,0x5B,0x23,0x88,0x2C,0x66,0x1C,0x6B,0x89,0x21,0xB2,0x98,0x71,0xAC,0x35,0x06,0xCB,0x43,0xC6,0xD5,0x96,0x42,0x2C,0x4F,0x11,0xDB,0x87,0x8B,0xB0,0x22,0x06,0x5C,0x2F,0x0E,0xC2,0xCA,0xE8,0xA8,0x73,0x38,0x88,0x28,0x93,0xA5,0xCC,0xD1,0xC0,0xA2,0xCC,0x96,0xBC,0x56,0x0D,0x93,0x2A,0x1A,0xAC,0x19,0x16,0x4A,0xAA,0xA4,0xB0,0xA6,0x55,0x28,0xA9,0x82,0xA2,0xE9,0x60,0xA9,0xA8,0x8A,0x12,0x27,0x8B,0xA9,0xA1,0x32,0x49,0xD8,0x28,0x82,0x87,0xCA,0x2C,0x60,0xA3,0x89,0x1D,0x2A,0x3C,0xC7,0x8D,0x24,0x66,0x00,0x00,0x00,0xF0};
they are different & talkie_low_battery_15 is longer yet they both sound the same IMHO. Why not re-use the “value” of “spLOWBATTERY” and just rename it “talkie_low_battery_15” ? BTW, this is not a critique, I am just trying to understand “what happened” or “why it happened”.
How about the “same-ish” algorithm as the one in use but simplified and optimized to “only be able to play” “the best possible” rate/energy/… for the one and only talkie that would remain for sd card missing/not found/insert SD … (if we choose to go that route). Again I have no idea how to do that, but would that be possible ? And would it reduce the size of the talkie code ?
I will start a new thread because I suspect that FONT_PATTERN can’t do what I expect it to do and that would make the FONT_PATTERN discussion irrelevant for the talkie enhancement.
