Proffie only recognizes the first font, top of the list.
Using the default fonts. Build is 89Sabers OWK with 1 button. Other brass button is a latch kill switch. Uh……help, please ?
What prop are you using?
Try holding the button and clash the blade (while off) ?
Post your config file?
Do you know the controls?
What have you tried?
What prop are you using? If I understand the question, I think none.
Try holding the button and clash the blade (while off) ? …THAT DID IT!!, thanks Fredrik !!
