I switched recently (with the ProffieOS7-Beta) from the BC-Propfile to the Fett-Propfile. Most things are working quite nice except one thing: While I was able to make multiple quick blasterdeflections via pressing buttons in the BC-File this was not possible in the Fett-File. In the latter one the saber just ignored button presses (and according to serial monitor - even just not recognize them while they work just fine in the BC-One). First guess was that saber runs out of wav players but the KILL_OLD_PLAYERS define didnβt work.
Here is the serial-monitor output from OS7-Fett Prop:
12:58:14.007 β EVENT: ?48 millis=131978
12:58:14.007 β EVENT MENU TURN LEFT
12:58:14.007 β EVENT: ?48 millis=132055
12:58:14.007 β EVENT: ?48 millis=132109
12:58:14.007 β EVENT: Swing millis=132112
12:58:14.007 β EVENT: Swing millis=132247
12:58:14.007 β EVENT: ?47 millis=132283
12:58:14.007 β EVENT MENU TURN RIGHT
12:58:14.007 β EVENT: Welcome to ProffieOS v7.0
12:58:14.007 β For available serial commands, see:
12:58:14.007 β ProffieOS Documentation: Serial Monitor Commands
12:58:14.007 β EVENT: Power-Pressed#1 millis=142747
12:58:14.007 β EVENT: Power-Pressed millis=142747
12:58:14.147 β EVENT: Power-Released#1 millis=142873
12:58:14.147 β EVENT: Power-Released millis=142873
12:58:14.147 β EVENT: Power-Shortclick#1 millis=142873
12:58:14.147 β EVENT: Power-Shortclick millis=142873
12:58:14.334 β EVENT: Power-SavedShortclick#1 millis=143048
12:58:14.334 β Ignition.
12:58:14.334 β unit = 0 vol = 0.00, Playing Revan/hum01.wav
12:58:14.334 β channels: 1 rate: 44100 bits: 16
12:58:14.334 β unit = 1 vol = 0.50, Playing Revan/out01.wav
12:58:14.381 β humstart: 100
12:58:14.381 β unit = 3 vol = 0.00, Playing Revan/swingl08.wav
12:58:14.381 β channels: 1 rate: 44100 bits: 16
12:58:14.381 β unit = 2 vol = 0.00, Playing Revan/swingh08.wav
12:58:14.802 β EVENT: ?48 ON millis=143512
12:58:14.802 β EVENT MENU TURN LEFT
12:58:15.506 β unit = 2 vol = 0.00, Playing Revan/swingl04.wav
12:58:15.506 β channels: 1 rate: 44100 bits: 16
12:58:15.553 β unit = 3 vol = 0.00, Playing Revan/swingh04.wav
12:58:15.553 β channels: 1 rate: 44100 bits: 16
12:58:16.588 β unit = 3 vol = 0.00, Playing Revan/swingl08.wav
12:58:16.588 β channels: 1 rate: 44100 bits: 16
12:58:16.588 β unit = 2 vol = 0.00, Playing Revan/swingh08.wav
12:58:16.634 β channels: 1 rate: 44100 bits: 16
12:58:16.728 β EVENT: Power-Pressed#1 ON millis=145443
12:58:16.728 β EVENT: Power-Pressed ON millis=145443
12:58:16.869 β EVENT: Power-Released#1 ON millis=145590
12:58:16.869 β EVENT: Power-Released ON millis=145590
12:58:16.869 β EVENT: Power-Shortclick#1 ON millis=145590
12:58:16.869 β EVENT: Power-Shortclick ON millis=145590
12:58:17.009 β EVENT: Power-SavedShortclick#1 ON millis=145744
12:58:17.009 β unit = 1 vol = 0.50, Playing Revan/blst04.wav
12:58:17.009 β channels: 1 rate: 44100 bits: 16
12:58:17.199 β EVENT: ?48 ON millis=145930
12:58:17.199 β EVENT MENU TURN LEFT
12:58:17.432 β EVENT: Power-Pressed#1 ON millis=146183
12:58:17.432 β EVENT: Power-Pressed ON millis=146183
12:58:17.620 β unit = 2 vol = 0.00, Playing Revan/swingl03.wav
12:58:17.620 β channels: 1 rate: 44100 bits: 16
12:58:17.620 β unit = 3 vol = 0.00, Playing Revan/swingh03.wav
12:58:17.620 β EVENT: Power-Released#1 ON millis=146356
12:58:17.620 β EVENT: Power-Released ON millis=146356
12:58:17.620 β EVENT: Power-Shortclick#1 ON millis=146356
12:58:17.620 β EVENT: Power-Shortclick ON millis=146356
12:58:17.761 β EVENT: Power-SavedShortclick#1 ON millis=146487
12:58:17.761 β unit = 1 vol = 0.50, Playing Revan/blst02.wav
12:58:17.761 β channels: 1 rate: 44100 bits: 16
12:58:18.088 β EVENT: Power-Pressed#1 ON millis=146841
12:58:18.088 β EVENT: Power-Pressed ON millis=146841
12:58:18.230 β EVENT: Power-Released#1 ON millis=146980
12:58:18.230 β EVENT: Power-Released ON millis=146980
12:58:18.230 β EVENT: Power-Shortclick#1 ON millis=146980
12:58:18.230 β EVENT: Power-Shortclick ON millis=146981
12:58:18.418 β EVENT: Power-SavedShortclick#1 ON millis=147143
12:58:18.418 β unit = 4 vol = 0.50, Playing Revan/blst04.wav
12:58:18.418 β channels: 1 rate: 44100 bits: 16
12:58:18.655 β unit = 2 vol = 0.00, Playing Revan/swingl03.wav
12:58:18.655 β channels: 1 rate: 44100 bits: 16
12:58:18.655 β unit = 3 vol = 0.00, Playing Revan/swingh03.wav
12:58:18.751 β EVENT: Power-Pressed#1 ON millis=147504
12:58:18.751 β EVENT: Power-Pressed ON millis=147504
12:58:18.938 β EVENT: Power-Released#1 ON millis=147665
12:58:18.938 β EVENT: Power-Released ON millis=147665
12:58:18.938 β EVENT: Power-Shortclick#1 ON millis=147665
12:58:18.938 β EVENT: Power-Shortclick ON millis=147665
12:58:19.080 β EVENT: Power-SavedShortclick#1 ON millis=147807
12:58:19.080 β unit = 1 vol = 0.50, Playing Revan/blst04.wav
12:58:19.080 β channels: 1 rate: 44100 bits: 16
12:58:19.410 β EVENT: Power-Pressed#1 ON millis=148154
12:58:19.410 β EVENT: Power-Pressed ON millis=148154
12:58:19.551 β Playing Revan/swingl03.wav
12:58:19.551 β channels: 1 rate: 44100 bits: 16
12:58:19.599 β Playing Revan/swingh03.wav
12:58:19.599 β channels: 1 rate: 44100 bits: 16
12:58:19.599 β EVENT: Power-Released#1 ON millis=148323
12:58:19.599 β EVENT: Power-Released ON millis=148324
12:58:19.599 β EVENT: Power-Shortclick#1 ON millis=148324
12:58:19.599 β EVENT: Power-Shortclick ON millis=148324
12:58:19.740 β EVENT: Power-SavedShortclick#1 ON millis=148461
12:58:19.740 β unit = 1 vol = 0.50, Playing Revan/blst06.wav
12:58:19.740 β channels: 1 rate: 44100 bits: 16
12:58:19.927 β unit = 3 vol = 0.00, Playing Revan/swingl04.wav
12:58:19.927 β channels: 1 rate: 44100 bits: 16
12:58:19.927 β unit = 2 vol = 0.00, Playing Revan/swingh04.wav
12:58:20.069 β EVENT: Power-Pressed#1 ON millis=148812
12:58:20.069 β EVENT: Power-Pressed ON millis=148812
12:58:20.211 β EVENT: Power-Released#1 ON millis=148960
12:58:20.211 β EVENT: Power-Released ON millis=148960
12:58:20.211 β EVENT: Power-Shortclick#1 ON millis=148960
12:58:20.211 β EVENT: Power-Shortclick ON millis=148961
12:58:20.398 β EVENT: Power-SavedShortclick#1 ON millis=149117
12:58:20.398 β unit = 1 vol = 0.50, Playing Revan/blst04.wav
12:58:20.493 β channels: 1 rate: 44100 bits: 16
12:58:20.493 β EVENT: Power-Pressed#1 ON millis=149229
12:58:20.493 β EVENT: Power-Pressed ON millis=149229
12:58:20.635 β EVENT: Power-Released#1 ON millis=149361
12:58:20.635 β EVENT: Power-Released ON millis=149361
12:58:20.635 β EVENT: Power-Shortclick#1 ON millis=149361
12:58:20.635 β EVENT: Power-Shortclick ON millis=149361
12:58:20.682 β Playing Revan/hum01.wav
12:58:20.682 β channels: 1 rate: 44100 bits: 16
12:58:20.823 β EVENT: Power-SavedShortclick#1 ON millis=149533
12:58:20.823 β unit = 4 vol = 0.50, Playing Revan/blst01.wav
12:58:20.823 β channels: 1 rate: 44100 bits: 16
12:58:20.917 β unit = 3 vol = 0.00, Playing Revan/swingl04.wav
12:58:20.963 β channels: 1 rate: 44100 bits: 16
12:58:20.963 β unit = 2 vol = 0.00, Playing Revan/swingh04.wav
12:58:21.151 β EVENT: Power-Pressed#1 ON millis=149896
12:58:21.151 β EVENT: Power-Pressed ON millis=149896
12:58:21.291 β EVENT: Power-Released#1 ON millis=150040
12:58:21.291 β EVENT: Power-Released ON millis=150040
12:58:21.291 β EVENT: Power-Shortclick#1 ON millis=150040
12:58:21.291 β EVENT: Power-Shortclick ON millis=150040
12:58:21.479 β EVENT: Power-SavedShortclick#1 ON millis=150197
12:58:21.479 β unit = 1 vol = 0.50, Playing Revan/blst02.wav
12:58:21.479 β channels: 1 rate: 44100 bits: 16
12:58:21.574 β EVENT: ?47 ON millis=150307
12:58:21.574 β EVENT MENU TURN RIGHT
12:58:21.621 β EVENT: Power-Pressed#1 ON millis=150335
12:58:21.621 β EVENT: Power-Pressed ON millis=150336
12:58:21.763 β EVENT: Power-Released#1 ON millis=150478
12:58:21.763 β EVENT: Power-Released ON millis=150481
12:58:21.763 β EVENT: Power-Shortclick#1 ON millis=150481
12:58:21.763 β EVENT: Power-Shortclick ON millis=150481
12:58:21.905 β EVENT: Power-SavedShortclick#1 ON millis=150644
12:58:21.905 β unit = 4 vol = 0.50, Playing Revan/blst03.wav
12:58:21.952 β channels: 1 rate: 44100 bits: 16
12:58:22.000 β unit = 3 vol = 0.00, Playing Revan/swingl03.wav
12:58:22.000 β channels: 1 rate: 44100 bits: 16
12:58:22.000 β unit = 2 vol = 0.00, Playing Revan/swingh03.wav
12:58:22.045 β channels: 1 rate: 44100 bits: 16
12:58:22.139 β EVENT: Power-Pressed#1 ON millis=150873
12:58:22.139 β EVENT: Power-Pressed ON millis=150874
12:58:22.277 β EVENT: Power-Released#1 ON millis=151023
12:58:22.277 β EVENT: Power-Released ON millis=151023
12:58:22.277 β EVENT: Power-Shortclick#1 ON millis=151023
12:58:22.277 β EVENT: Power-Shortclick ON millis=151025
12:58:22.464 β EVENT: Power-SavedShortclick#1 ON millis=151177
12:58:22.464 β unit = 1 vol = 0.50, Playing Revan/blst01.wav
12:58:22.464 β channels: 1 rate: 44100 bits: 16
12:58:22.604 β EVENT: ?47 ON millis=151342
12:58:22.604 β EVENT MENU TURN RIGHT
12:58:22.697 β EVENT: Power-Pressed#1 ON millis=151440
12:58:22.697 β EVENT: Power-Pressed ON millis=151440
12:58:22.841 β EVENT: Power-Released#1 ON millis=151591
12:58:22.841 β EVENT: Power-Released ON millis=151591
12:58:22.841 β EVENT: Power-Shortclick#1 ON millis=151591
12:58:22.841 β EVENT: Power-Shortclick ON millis=151591
12:58:23.029 β EVENT: Power-SavedShortclick#1 ON millis=151741
12:58:23.029 β unit = 4 vol = 0.50, Playing Revan/blst05.wav
12:58:23.029 β channels: 1 rate: 44100 bits: 16
12:58:23.122 β unit = 2 vol = 0.00, Playing Revan/swingl08.wav
12:58:23.122 β channels: 1 rate: 44100 bits: 16
12:58:23.122 β unit = 3 vol = 0.00, Playing Revan/swingh08.wav
12:58:23.263 β EVENT: Power-Pressed#1 ON millis=151981
12:58:23.263 β EVENT: Power-Pressed ON millis=151981
12:58:23.357 β EVENT: ?47 mods Power ON millis=152109
12:58:23.357 β EVENT MENU TURN RIGHT
12:58:23.357 β EVENT: Power-Released#1 ON millis=152112
12:58:23.405 β EVENT: Power-Released ON millis=152114
12:58:23.971 β EVENT: ?48 ON millis=152682
12:58:23.971 β EVENT MENU TURN LEFT
12:58:24.111 β EVENT: Power-Pressed#1 ON millis=152853
12:58:24.111 β EVENT: Power-Pressed ON millis=152853
12:58:24.159 β unit = 2 vol = 0.00, Playing Revan/swingl03.wav
12:58:24.159 β channels: 1 rate: 44100 bits: 16
12:58:24.206 β unit = 3 vol = 0.00, Playing Revan/swingh03.wav
12:58:24.206 β channels: 1 rate: 44100 bits: 16
12:58:24.253 β EVENT: Power-Released#1 ON millis=152984
12:58:24.253 β EVENT: Power-Released ON millis=152985
12:58:24.253 β EVENT: Power-Shortclick#1 ON millis=152985
12:58:24.253 β EVENT: Power-Shortclick ON millis=152985
12:58:24.442 β EVENT: Power-SavedShortclick#1 ON millis=153158
12:58:24.442 β unit = 1 vol = 0.50, Playing Revan/blst06.wav
12:58:24.442 β channels: 1 rate: 44100 bits: 16
12:58:24.630 β EVENT: Power-Pressed#1 ON millis=153339
12:58:24.630 β EVENT: Power-Pressed ON millis=153339
12:58:24.725 β EVENT: ?47 mods Power ON millis=153470
12:58:24.725 β EVENT MENU TURN RIGHT
12:58:24.725 β EVENT: Power-Released#1 ON millis=153477
12:58:24.725 β EVENT: Power-Released ON millis=153477
12:58:25.101 β EVENT: Power-Pressed#1 ON millis=153847
12:58:25.101 β EVENT: Power-Pressed ON millis=153847
12:58:25.290 β EVENT: Power-Released#1 ON millis=154006
12:58:25.290 β EVENT: Power-Released ON millis=154006
12:58:25.290 β EVENT: Power-Shortclick#1 ON millis=154006
12:58:25.290 β EVENT: Power-Shortclick ON millis=154006
12:58:25.383 β EVENT: ?48 ON millis=154123
12:58:25.383 β EVENT MENU TURN LEFT
12:58:25.430 β EVENT: Power-SavedShortclick#1 ON millis=154149
12:58:25.430 β unit = 1 vol = 0.50, Playing Revan/blst03.wav
12:58:25.430 β channels: 1 rate: 44100 bits: 16
12:58:25.523 β unit = 3 vol = 0.00, Playing Revan/swingl01.wav
12:58:25.523 β channels: 1 rate: 44100 bits: 16
12:58:25.570 β unit = 2 vol = 0.00, Playing Revan/swingh01.wav
12:58:25.570 β channels: 1 rate: 44100 bits: 16
12:58:25.663 β EVENT: Power-Pressed#1 ON millis=154418
12:58:25.663 β EVENT: Power-Pressed ON millis=154418
12:58:25.852 β EVENT: Power-Released#1 ON millis=154571
12:58:25.852 β EVENT: Power-Released ON millis=154571
12:58:25.852 β EVENT: Power-Shortclick#1 ON millis=154571
12:58:25.852 β EVENT: Power-Shortclick ON millis=154571
12:58:25.994 β EVENT: Power-SavedShortclick#1 ON millis=154721
12:58:25.994 β unit = 4 vol = 0.50, Playing Revan/blst01.wav
12:58:25.994 β channels: 1 rate: 44100 bits: 16
12:58:25.994 β Playing Revan/swingl01.wav
12:58:26.041 β Playing Revan/swingh01.wav
12:58:26.041 β channels: 1 rate: 44100 bits: 16
12:58:26.309 β EVENT: Power-Pressed#1 ON millis=155058
12:58:26.309 β EVENT: Power-Pressed ON millis=155058
12:58:26.402 β EVENT: ?48 mods Power ON millis=155150
12:58:26.402 β EVENT MENU TURN LEFT
12:58:26.496 β EVENT: Power-Released#1 ON millis=155220
12:58:26.496 β EVENT: Power-Released ON millis=155221
12:58:26.543 β EVENT: ?48 ON millis=155279
12:58:26.543 β EVENT MENU TURN LEFT
12:58:26.685 β unit = 2 vol = 0.00, Playing Revan/swingl06.wav
12:58:26.685 β channels: 1 rate: 44100 bits: 16
12:58:26.685 β unit = 3 vol = 0.00, Playing Revan/swingh06.wav
12:58:27.017 β Playing Revan/hum01.wav
12:58:27.017 β channels: 1 rate: 44100 bits: 16
12:58:27.254 β EVENT: Power-Pressed#1 ON millis=155983
12:58:27.254 β EVENT: Power-Pressed ON millis=155983
12:58:27.397 β EVENT: Power-Released#1 ON millis=156146
12:58:27.397 β EVENT: Power-Released ON millis=156146
12:58:27.397 β EVENT: Power-Shortclick#1 ON millis=156146
12:58:27.397 β EVENT: Power-Shortclick ON millis=156146
12:58:27.536 β EVENT: ?47 ON millis=156248
12:58:27.536 β EVENT MENU TURN RIGHT
12:58:27.536 β EVENT: Power-SavedShortclick#1 ON millis=156288
12:58:27.536 β unit = 1 vol = 0.50, Playing Revan/blst01.wav
12:58:27.583 β channels: 1 rate: 44100 bits: 16
12:58:27.677 β EVENT: ?47 ON millis=156411
12:58:27.677 β EVENT MENU TURN RIGHT
12:58:27.770 β EVENT: Power-Pressed#1 ON millis=156511
12:58:27.770 β EVENT: Power-Pressed ON millis=156511
12:58:27.959 β unit = 3 vol = 0.00, Playing Revan/swingl06.wav
12:58:27.959 β channels: 1 rate: 44100 bits: 16
12:58:27.959 β unit = 2 vol = 0.00, Playing Revan/swingh06.wav
12:58:28.005 β EVENT: Power-Released#1 ON millis=156717
12:58:28.005 β EVENT: Power-Released ON millis=156717
12:58:28.005 β EVENT: Power-Shortclick#1 ON millis=156717
12:58:28.005 β EVENT: Power-Shortclick ON millis=156717
12:58:28.099 β EVENT: Power-SavedShortclick#1 ON millis=156812
12:58:28.099 β unit = 4 vol = 0.50, Playing Revan/blst04.wav
12:58:28.099 β channels: 1 rate: 44100 bits: 16
12:58:28.378 β EVENT: Power-Pressed#1 ON millis=157091
12:58:28.378 β EVENT: Power-Pressed ON millis=157091
12:58:28.520 β EVENT: Power-Released#1 ON millis=157270
12:58:28.520 β EVENT: Power-Released ON millis=157270
12:58:28.520 β EVENT: Power-Shortclick#1 ON millis=157270
12:58:28.567 β EVENT: Power-Shortclick ON millis=157270
12:58:28.567 β EVENT: ?47 ON millis=157277
12:58:28.567 β EVENT MENU TURN RIGHT
12:58:28.661 β EVENT: Power-SavedShortclick#1 ON millis=157392
12:58:28.661 β unit = 1 vol = 0.50, Playing Revan/blst01.wav
12:58:28.661 β channels: 1 rate: 44100 bits: 16
12:58:28.944 β EVENT: Power-Pressed#1 ON millis=157698
12:58:28.944 β EVENT: Power-Pressed ON millis=157698
12:58:29.178 β unit = 2 vol = 0.00, Playing Revan/swingl07.wav
12:58:29.178 β channels: 1 rate: 44100 bits: 16
12:58:29.178 β unit = 3 vol = 0.00, Playing Revan/swingh07.wav
12:58:29.178 β EVENT: Power-Released#1 ON millis=157927
12:58:29.178 β EVENT: Power-Released ON millis=157927
12:58:29.178 β EVENT: Power-Shortclick#1 ON millis=157928
12:58:29.178 β EVENT: Power-Shortclick ON millis=157928
12:58:29.272 β EVENT: Power-SavedShortclick#1 ON millis=158004
12:58:29.272 β unit = 4 vol = 0.50, Playing Revan/blst04.wav
12:58:29.272 β channels: 1 rate: 44100 bits: 16
12:58:29.697 β EVENT: ?47 ON millis=158441
12:58:29.697 β EVENT MENU TURN RIGHT
12:58:29.932 β EVENT: ?47 ON millis=158665
12:58:29.932 β EVENT MENU TURN RIGHT
12:58:30.357 β unit = 2 vol = 0.00, Playing Revan/swingl07.wav
12:58:30.357 β channels: 1 rate: 44100 bits: 16
12:58:30.357 β unit = 3 vol = 0.00, Playing Revan/swingh07.wav
12:58:31.299 β Battery voltage: 3.92
12:58:31.536 β EVENT: ?48 ON millis=160248
12:58:31.536 β EVENT MENU TURN LEFT
12:58:31.583 β EVENT: Swing ON millis=160318
12:58:31.583 β EVENT: ?48 ON millis=160327
12:58:31.583 β EVENT MENU TURN LEFT
12:58:31.677 β EVENT: ?48 ON millis=160381
12:58:31.677 β EVENT MENU TURN LEFT
12:58:31.772 β unit = 2 vol = 0.00, Playing Revan/swingl04.wav
12:58:31.772 β channels: 1 rate: 44100 bits: 16
12:58:31.772 β unit = 3 vol = 0.00, Playing Revan/swingh04.wav
12:58:31.911 β EVENT: Power-Pressed#1 ON millis=160664
12:58:31.911 β EVENT: Power-Pressed ON millis=160665
12:58:32.101 β EVENT: ?48 mods Power ON millis=160811
12:58:32.101 β EVENT MENU TURN LEFT
12:58:32.194 β EVENT: ?48 ON millis=160916
12:58:32.194 β EVENT MENU TURN LEFT
12:58:32.383 β EVENT: ?48 ON millis=161084
12:58:32.383 β EVENT MENU TURN LEFT
12:58:32.476 β Playing Revan/swingl04.wav
12:58:32.476 β channels: 1 rate: 44100 bits: 16
12:58:32.476 β Playing Revan/swingh04.wav
12:58:33.369 β Playing Revan/hum01.wav
12:58:33.369 β channels: 1 rate: 44100 bits: 16
12:58:33.796 β unit = 2 vol = 0.00, Playing Revan/swingl06.wav
12:58:33.796 β channels: 1 rate: 44100 bits: 16
12:58:33.796 β unit = 3 vol = 0.00, Playing Revan/swingh06.wav
12:58:35.817 β EVENT: ?47 ON millis=164534
12:58:35.817 β EVENT MENU TURN RIGHT
12:58:35.864 β EVENT: Power-Released#1 ON millis=164607
12:58:35.864 β EVENT: Power-Released ON millis=164607
12:58:36.192 β unit = 2 vol = 0.00, Playing Revan/swingl04.wav
12:58:36.192 β channels: 1 rate: 44100 bits: 16
12:58:36.192 β unit = 3 vol = 0.00, Playing Revan/swingh04.wav
12:58:36.947 β EVENT: Power-Pressed#1 ON millis=165690
12:58:36.947 β EVENT: Power-Pressed ON millis=165690
12:58:37.276 β EVENT: Power-Held#1 ON millis=165992
12:58:37.276 β EVENT: Power-Held ON millis=165992
12:58:37.746 β EVENT: Power-HeldMedium#1 ON millis=166491
12:58:37.746 β EVENT: Power-HeldMedium ON millis=166491
12:58:38.925 β Playing Revan/swingl04.wav
12:58:38.925 β channels: 1 rate: 44100 bits: 16
12:58:38.925 β Playing Revan/swingh04.wav
12:58:38.972 β EVENT: Power-HeldLong#1 ON millis=167693
12:58:38.972 β unit = 1 vol = 0.50, Playing Revan/in01.wav
12:58:38.972 β channels: 1 rate: 44100 bits: 16
12:58:39.398 β EVENT: Power-Released#1 millis=168130
12:58:39.398 β EVENT: Power-Released millis=168130
12:58:39.586 β EVENT: ?48 millis=168314
12:58:39.586 β EVENT MENU TURN LEFT
12:58:39.634 β EVENT: ?48 millis=168354
12:58:39.634 β EVENT MENU TURN LEFT
12:58:39.681 β EVENT: ?48 millis=168392
12:58:39.681 β EVENT MENU TURN LEFT
12:58:39.775 β EVENT: ?48 millis=168502
12:58:39.775 β EVENT MENU TURN LEFT
12:58:39.869 β No sounds found: pstoff
12:58:39.915 β Amplifier off.
12:58:40.903 β Unmounting SD Card.
12:58:43.545 β EVENT: Swing millis=172287
12:58:43.591 β EVENT: ?47 millis=172307
12:58:43.591 β EVENT MENU TURN RIGHT
12:58:43.637 β EVENT: ?47 millis=172368
12:58:43.637 β EVENT MENU TURN RIGHT
12:58:43.685 β EVENT: ?47 millis=172412
12:58:43.685 β EVENT MENU TURN RIGHT
12:58:43.780 β Booster off.
12:58:43.780 β EVENT: ?47 millis=172516
12:58:43.780 β EVENT MENU TURN RIGHT
12:58:44.298 β EVENT: ?47 millis=173041
12:58:44.298 β EVENT MENU TURN RIGHT
And here the one from BCs Propfile on Proffie-OS 6.7 (as it doesnβt work under 7 quite now):
13:14:00.079 β EVENT: Swing millis=366590
13:14:00.079 β EVENT: Clash millis=368861
13:14:00.079 β Battery voltage: 4.04
13:14:00.079 β Welcome to ProffieOS v6.7. Type βhelpβ for more info.
13:14:01.103 β EVENT: Power-Pressed#1 millis=381370
13:14:01.103 β EVENT: Power-Pressed millis=381370
13:14:01.243 β EVENT: Power-Released#1 millis=381476
13:14:01.243 β EVENT: Power-Released millis=381476
13:14:01.243 β EVENT: Power-Shortclick#1 millis=381477
13:14:01.243 β EVENT: Power-Shortclick millis=381477
13:14:01.430 β EVENT: Power-SavedShortclick#1 millis=381672
13:14:01.430 β Ignition.
13:14:01.430 β unit = 0 vol = 0.00, Playing DarkSaber/hum/hum01.wav
13:14:01.430 β channels: 1 rate: 44100 bits: 16
13:14:01.477 β unit = 1 vol = 0.50, Playing DarkSaber/out/out02.wav
13:14:01.477 β channels: 1 rate: 44100 bits: 16
13:14:01.477 β humstart: 1800
13:14:01.477 β unit = 3 vol = 0.00, Playing DarkSaber/swingl/swingl01.wav
13:14:01.477 β unit = 4 vol = 0.00, Playing DarkSaber/swingh/swingh01.wav
13:14:05.106 β EVENT: Power-Pressed#1 ON millis=385376
13:14:05.106 β EVENT: Power-Pressed ON millis=385376
13:14:05.247 β EVENT: Power-Released#1 ON millis=385490
13:14:05.247 β EVENT: Power-Released ON millis=385490
13:14:05.247 β EVENT: Power-Shortclick#1 ON millis=385490
13:14:05.247 β EVENT: Power-Shortclick ON millis=385490
13:14:05.436 β EVENT: Power-SavedShortclick#1 ON millis=385681
13:14:05.436 β unit = 1 vol = 0.50, Playing DarkSaber/blst/blst04.wav
13:14:05.436 β channels: 1 rate: 44100 bits: 16
13:14:05.483 β EVENT: Stab ON millis=385726
13:14:05.483 β unit = 2 vol = 0.50, Playing DarkSaber/bgnlock/bgnlock.wav
13:14:05.483 β channels: 1 rate: 44100 bits: 16
13:14:05.717 β EVENT: Power-Pressed#1 ON millis=385969
13:14:05.717 β EVENT: Power-Pressed ON millis=385969
13:14:05.808 β EVENT: Power-Released#1 ON millis=386081
13:14:05.808 β EVENT: Power-Released ON millis=386081
13:14:05.855 β unit = 5 vol = 0.50, Playing DarkSaber/endlock/endlock.wav
13:14:05.855 β channels: 1 rate: 44100 bits: 16
13:14:05.855 β unit = 3 vol = 0.00, Playing DarkSaber/swingl/swingl04.wav
13:14:05.855 β unit = 4 vol = 0.00, Playing DarkSaber/swingh/swingh04.wav
13:14:05.902 β channels: 1 rate: 44100 bits: 16
13:14:06.185 β EVENT: Power-Pressed#1 ON millis=386421
13:14:06.185 β EVENT: Power-Pressed ON millis=386421
13:14:06.280 β EVENT: Power-Released#1 ON millis=386536
13:14:06.280 β EVENT: Power-Released ON millis=386536
13:14:06.280 β EVENT: Power-Shortclick#1 ON millis=386536
13:14:06.280 β EVENT: Power-Shortclick ON millis=386536
13:14:06.468 β EVENT: Power-SavedShortclick#1 ON millis=386722
13:14:06.468 β unit = 1 vol = 0.50, Playing DarkSaber/blst/blst04.wav
13:14:06.468 β channels: 1 rate: 44100 bits: 16
13:14:06.564 β EVENT: Power-Pressed#1 ON millis=386827
13:14:06.564 β EVENT: Power-Pressed ON millis=386827
13:14:06.659 β EVENT: Power-Released#1 ON millis=386933
13:14:06.659 β EVENT: Power-Released ON millis=386934
13:14:06.659 β EVENT: Power-Shortclick#1 ON millis=386936
13:14:06.659 β EVENT: Power-Shortclick ON millis=386936
13:14:06.894 β EVENT: Power-SavedShortclick#1 ON millis=387143
13:14:06.894 β unit = 2 vol = 0.50, Playing DarkSaber/blst/blst01.wav
13:14:06.894 β channels: 1 rate: 44100 bits: 16
13:14:06.987 β EVENT: Power-Pressed#1 ON millis=387250
13:14:06.987 β EVENT: Power-Pressed ON millis=387250
13:14:07.127 β EVENT: Power-Released#1 ON millis=387401
13:14:07.127 β EVENT: Power-Released ON millis=387401
13:14:07.127 β EVENT: Power-Shortclick#1 ON millis=387401
13:14:07.127 β EVENT: Power-Shortclick ON millis=387401
13:14:07.316 β EVENT: Power-SavedShortclick#1 ON millis=387569
13:14:07.316 β unit = 5 vol = 0.50, Playing DarkSaber/blst/blst05.wav
13:14:07.316 β channels: 1 rate: 44100 bits: 16
13:14:07.363 β EVENT: Power-Pressed#1 ON millis=387641
13:14:07.363 β EVENT: Power-Pressed ON millis=387641
13:14:07.503 β EVENT: Power-Released#1 ON millis=387760
13:14:07.503 β EVENT: Power-Released ON millis=387760
13:14:07.503 β EVENT: Power-Shortclick#1 ON millis=387761
13:14:07.503 β EVENT: Power-Shortclick ON millis=387761
13:14:07.691 β EVENT: Power-SavedShortclick#1 ON millis=387960
13:14:07.691 β unit = 1 vol = 0.50, Playing DarkSaber/blst/blst02.wav
13:14:07.738 β channels: 1 rate: 44100 bits: 16
13:14:07.785 β EVENT: Power-Pressed#1 ON millis=388033
13:14:07.785 β EVENT: Power-Pressed ON millis=388033
13:14:07.926 β EVENT: Power-Released#1 ON millis=388190
13:14:07.926 β EVENT: Power-Released ON millis=388190
13:14:07.926 β EVENT: Power-Shortclick#1 ON millis=388190
13:14:07.926 β EVENT: Power-Shortclick ON millis=388192
13:14:08.113 β EVENT: Power-SavedShortclick#1 ON millis=388358
13:14:08.113 β unit = 2 vol = 0.50, Playing DarkSaber/blst/blst03.wav
13:14:08.113 β channels: 1 rate: 44100 bits: 16
13:14:08.160 β EVENT: Power-Pressed#1 ON millis=388427
13:14:08.160 β EVENT: Power-Pressed ON millis=388428
13:14:08.207 β EVENT: Power-Released#1 ON millis=388480
13:14:08.207 β EVENT: Power-Released ON millis=388480
13:14:08.207 β EVENT: Power-Shortclick#1 ON millis=388480
13:14:08.207 β EVENT: Power-Shortclick ON millis=388480
13:14:08.255 β Playing DarkSaber/swingl/swingl04.wav
13:14:08.255 β channels: 1 rate: 44100 bits: 16
13:14:08.443 β EVENT: Power-Pressed#2 ON millis=388680
13:14:08.443 β EVENT: Power-Pressed ON millis=388680
13:14:08.583 β EVENT: Power-Released#2 ON millis=388849
13:14:08.583 β EVENT: Power-Released ON millis=388849
13:14:08.583 β EVENT: Power-Shortclick#2 ON millis=388849
13:14:08.583 β EVENT: Power-Shortclick ON millis=388849
13:14:08.723 β EVENT: Power-SavedShortclick#2 ON millis=388983
13:14:08.723 β unit = 1 vol = 0.50, Playing DarkSaber/blst/blst02.wav
13:14:08.723 β channels: 1 rate: 44100 bits: 16
13:14:08.865 β EVENT: Power-Pressed#1 ON millis=389109
13:14:08.865 β EVENT: Power-Pressed ON millis=389109
13:14:09.008 β EVENT: Power-Released#1 ON millis=389256
13:14:09.008 β EVENT: Power-Released ON millis=389256
13:14:09.008 β EVENT: Power-Shortclick#1 ON millis=389256
13:14:09.008 β EVENT: Power-Shortclick ON millis=389256
13:14:09.150 β EVENT: Power-SavedShortclick#1 ON millis=389413
13:14:09.150 β unit = 2 vol = 0.50, Playing DarkSaber/blst/blst01.wav
13:14:09.197 β channels: 1 rate: 44100 bits: 16
13:14:09.244 β EVENT: Power-Pressed#1 ON millis=389482
13:14:09.244 β EVENT: Power-Pressed ON millis=389482
13:14:09.338 β EVENT: Power-Released#1 ON millis=389602
13:14:09.338 β EVENT: Power-Released ON millis=389602
13:14:09.338 β EVENT: Power-Shortclick#1 ON millis=389602
13:14:09.338 β EVENT: Power-Shortclick ON millis=389602
13:14:09.526 β EVENT: Power-SavedShortclick#1 ON millis=389783
13:14:09.526 β unit = 5 vol = 0.50, Playing DarkSaber/blst/blst04.wav
13:14:09.573 β channels: 1 rate: 44100 bits: 16
13:14:09.573 β EVENT: Power-Pressed#1 ON millis=389853
13:14:09.573 β EVENT: Power-Pressed ON millis=389853
13:14:09.760 β EVENT: Power-Released#1 ON millis=389999
13:14:09.760 β EVENT: Power-Released ON millis=389999
13:14:09.760 β EVENT: Power-Shortclick#1 ON millis=389999
13:14:09.760 β EVENT: Power-Shortclick ON millis=390003
13:14:09.902 β EVENT: Power-SavedShortclick#1 ON millis=390179
13:14:09.902 β unit = 1 vol = 0.50, Playing DarkSaber/blst/blst01.wav
13:14:09.948 β channels: 1 rate: 44100 bits: 16
13:14:09.996 β EVENT: Power-Pressed#1 ON millis=390249
13:14:09.996 β EVENT: Power-Pressed ON millis=390251
13:14:10.328 β EVENT: Power-Held#1 ON millis=390572
13:14:10.328 β EVENT: Power-Held ON millis=390573
13:14:10.799 β EVENT: Power-HeldMedium#1 ON millis=391052
13:14:10.799 β unit = 2 vol = 0.50, Playing DarkSaber/in/in01.wav
13:14:10.799 β channels: 1 rate: 44100 bits: 16
13:14:11.220 β EVENT: Power-Released#1 millis=391490
13:14:11.220 β EVENT: Power-Released millis=391490
13:14:16.076 β Playing DarkSaber/pstoff.wav
13:14:16.076 β channels: 1 rate: 44100 bits: 16
13:14:16.076 β Amplifier off.
13:14:17.020 β Unmounting SD Card.
13:14:17.066 β Booster off.
I hope you can help me. Iβd love to try out all those fancy new things from ProffieOS7 but more important is that my saber works accurate as it is mostly used for LARP-Purposes^^"
Thanks in advance
Yen
