Is there a parameter to extend the blast range on the blade all the way from hilt to tip?
Depends on the style. If it has a Scale<> function you can adjust the values.
It has a bump scale. Can i add another? this is the style.
StylePtr<Layers< Black, TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<EFFECT_BLAST>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Red>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Red>>>,TrFade<300>>,EFFECT_BLAST>, Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,White>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>, LockupTrL<AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,OrangeRed>>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,OrangeRed>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,OrangeRed>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,OrangeRed>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>, ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,DarkOrange>,AudioFlicker<RgbArg<LB_COLOR_ARG,DarkOrange>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,DarkOrange>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,DarkOrange>,Int<16000>>,30>,TrSmoothFade<600>>>, LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrWipeIn<200>,TrFade<300>,SaberBase::LOCKUP_DRAG>, LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>, InOutTrL<TrWipeX<IgnitionTime<>>,TrWipeInX<RetractionTime<>>>, TransitionEffectL<TrConcat<TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,Red,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,Orange,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,White,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>>,EFFECT_PREON>>>()
EffectPosition<EFFECT_BLAST> should already allow 0 ~ 32768.
You could try EffectRandomF<EFFECT_BLAST> instead.
Ok Thanks. I will try to set it. Thank you!
Just wanted to say the EffectRandomF<EFFECT_BLAST>
worked way better. Went to the emitter side further. The effect blast variables you mentioned before, adjusted the size of the blast bolt top and bottom which for me did just that…but didn’t expand the range from blade end to blade end for me. but this option will work for now.
