Bladeid 1023.00 how to setup the no blade
That’s already on the config. Did you read the config?
I did read it, but either I didn’t read the last one, or I missed it before.
If you run “scanid” with no blade id, what do you get?
And do you still get about 1023 when you run it with the blade in?
Yes I tested it several times to get that number?
so I would need to wire a new pin to which pin?
can you show on a diagram?
Did you try this?
Any GPIO-capable pin will work, so Data*, Button*, Rx, Tx.
It would be wired to a free pogo pin. When the blade is inserted, that pogo pin gets connected to something, which triggers the blade detect.
It shoulld still be possible to do all this stuff without blade detect though.
The V3 config generator can provide an example of how it’s done:
Just check the “blade detect” checkbox.
so I did it without the blade and it’s reading
> scanid
BLADE ID: 1000000704.00
do I need to add this number to the
#define NO_BLADE_ID_RANGE 100,1000
so I compiled and flashed, but my expectation was that if I set the blade id and blade detect it would play the bladein and bladeout wav files, if I have lightsaber blade on or off but that didn’t happen.
also the bladearray no_blade only had 1 preset. but all my other fonts are loaded as well.
e.g.
// ProffieOS7 Config File
#define NUM_BUTTONS 1
#define VOLUME 1650
#define CLASH_THRESHOLD_G 3
#define AUDIO_CLASH_SUPPRESSION_LEVEL 10
#define SAVE_STATE
#define FILTER_ORDER 8
#define SHARED_POWER_PINS
#define BLADE_ID_SCAN_TIMEOUT 5 * 60 * 1000
#define MOUNT_SD_SETTING
#define BUTTON_LONG_CLICK_TIMEOUT 2500
#define BLADE_ID_STOP_SCAN_WHEN_IGNITED
#define FETT263_MAX_CLASH 16
#define FETT263_SPIN_MODE
#define FETT263_QUICK_SELECT_ON_BOOT
#define FETT263_TWIST_ON
#define FETT263_THRUST_ON
#define FETT263_STAB_ON
#define FETT263_FORCE_PUSH
#define FETT263_CIRCULAR_VOLUME_MENU
#define FETT263_CIRCULAR_DIM_MENU
#define FETT263_SS_BUTTON_CLICKER
#define FETT263_SWING_CLASH_DELAY 150
Preset blade_in[] = {
{ "BalVenos;BalVenos/common",  "tracks/Star Wars Medley (Violin Cover) - Taylor Davis.wav",
OS7.15 v3.218p
This Style Contains 108 Unique Combinations
Multi Phase (Force Change) Transition: Fade, Time: 1000
Default: Crucible Flame (Normal) [BaseColorArg]
1: Unstable Rage [AltColorArg]
Multi Phase Control: use Force to toggle phases.
Preon Effect Options: Default (0): Faulty Ignition, 1: Sparking, 2: Pilot Light [Color: PreonColorArg]
Ignition Effect Options: Default (0): SparkTip Ignition, 1: Dual Mode Wipe (Down = Fast), 2: Glitch On [Color: IgnitionColorArg]
Retraction Effect Options: Default (0): SparkTip Retraction, 1: Dual Mode Wipe In (Up = Fast), 2: Glitch Off [Color: RetractionColorArg]
PostOff Effect Options: Default (0): Disable, 1: Emitter Cool Off (Emitter Size), 2: Emitter Spark (Emitter Size), 3: Battery Glow (Preon Size) [Color: PostOffColorArg]
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Stab Effect: Sparking Stab [Color: StabColorArg]
Blast Effect (Randomly Selected): Responsive Blast Wave (Medium), Responsive Blast Wave (Random), Responsive Blast Wave (Large) [Color: BlastColorArg]
Clash Effect: Real Clash V3 [Color: ClashColorArg]
Display Volume: % Blade [Color: BaseColorArg]
Battery Monitor: Passive Battery Monitor (Change Preset)
Power Save: 10% Increment
StylePtr<Layers<Black,ColorSelect<IncrementModuloF<EffectPulseF<EFFECT_FORCE>,Int<32000>>,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrFadeX<Int<1000>>>,StaticFire<Stripes<12000,-1000,RgbArg<BASE_COLOR_ARG,Rgb<255,0,75>>,RotateColorsX<Int<200>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,75>>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,75>>>,0,2,2,2000,4>,Stripes<3000,-3500,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<200>,Int<200>,Int<400>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<200>,Int<100>,Int<400>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<180,180,255>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,3992>,Int<98304>>>>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,IgnitionTime<0>,Mult<IgnitionTime<0>,Int<16384>>>>,TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<0>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<180,180,255>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<RetractionTime<0>,Int<16384>>,RetractionTime<0>>>,TrConcat<TrJoin<TrDelayX<Mult<RetractionTime<0>,Int<16384>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,75>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>>,Black>,TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Mult<Int<16384>,WavLen<EFFECT_PREON>>,Mult<Int<10922>,WavLen<EFFECT_PREON>>,Mult<Int<5462>,WavLen<EFFECT_PREON>>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<191,255,255>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<191,255,255>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<191,255,255>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<191,255,255>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<191,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<PREON_SIZE_ARG,2000>,Sum<IntArg<PREON_SIZE_ARG,2000>,Int<4000>>>,Int<-2000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrExtendX<WavLen<EFFECT_PREON>,TrInstant>,AlphaL<PulsingL<Mix<Int<16384>,White,RgbArg<PREON_COLOR_ARG,Rgb<191,255,255>>>,Int<300>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrLoopN<9,TrBoingX<Mult<WavLen<EFFECT_PREON>,Int<2458>>,3>>>>,EFFECT_PREON>,TransitionEffectL<TrSelect<IntArg<OFF_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<POSTOFF_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<3000>>>,Int<-4000>>>,TrDelayX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrJoin<TrDelayX<Int<500>>,TrFade<500>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFade<500>>>,EFFECT_POSTOFF>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<100>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,0,75>>,SmoothStep<VolumeLevel,Int<-1>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
"Bal Venos"
{ "bank02;bank02/common",  "tracks/Finalsteps.wav",
OS7.15 v3.218p
This Style Contains 81 Unique Combinations
Style Options:
1: Hyper Responsive Rotoscope (Prequels)
2: Hyper Responsive Rotoscope (Sequels)
Base Color: BaseColorArg (0)
Preon Effect Options: Default (0): Disable, 1: Rey TROS Spark, 2: Overload [Color: PreonColorArg]
Ignition Effect Options: Default (0): Standard Ignition, 1: SparkTip Ignition, 2: Dual Mode Wipe (Down = Fast) [Color: IgnitionColorArg]
Retraction Effect Options: Default (0): SparkTip Retraction, 1: Dual Mode Wipe In (Up = Fast), 2: Standard Retraction [Color: RetractionColorArg]
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
Stab Effect: AudioFlicker Stab [Color: StabColorArg]
Blast Effect (Randomly Selected): Responsive Blast Wave (Random), Responsive Blast Ripple, Responsive Blast Fade (Random) [Color: BlastColorArg]
StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<24000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-1400>,Int<-100>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Remap<CenterDistF<Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,IgnitionTime<300>,Mult<IgnitionTime<300>,Int<16384>>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<RetractionTime<0>,Int<16384>>,RetractionTime<0>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>,Black>,TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrInstant,TrConcat<TrJoin<TrDelayX<Int<100>>,TrInstant>,AlphaL<Green,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrWipe<100>,AlphaL<DodgerBlue,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrDelayX<Sum<WavLen<EFFECT_PREON>,Int<200>>>>,TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<100>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,SmoothStep<VolumeLevel,Int<-1>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
"Rey Skywalker"
{ "Bank18;bank18/common",  "track/Ahsoka.wav",
/* copyright Fett263 Ahsoka (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#Ahsoka
OS7.15 v3.218p
This Style Contains 9 Unique Combinations
Base Style: Ahsoka Tano
Preon Effect: Overload [Color: PreonColorArg]
Ignition Effect Options: Default (0): SparkTip Ignition, 1: Standard Ignition, 2: Dual Mode Wipe (Down = Fast) [Color: IgnitionColorArg]
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<AudioFlicker<Stripes<22000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<10000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<18000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Remap<CenterDistF<Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,IgnitionTime<300>,Mult<IgnitionTime<300>,Int<16384>>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<RetractionTime<0>,Int<16384>>,RetractionTime<0>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<100>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,SmoothStep<VolumeLevel,Int<-1>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
"Master Ahsoka"
{ "bank01;Bank01/common",  "bank01/Extras/Kylo_Theme.wav",
/* copyright Fett263 KyloRen (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#KyloRen
OS7.15 v3.218p
Style Options:
Default (0): Kylo Ren Unstable (Film Based)
1: Kylo Ren Unstable (Supreme Leader)
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<3213>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,6,10,1000,2>,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<119,34,34>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<119,34,34>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<119,34,34>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<100>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,SmoothStep<VolumeLevel,Int<-1>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
"Kylo Ren"
{ "KnightRider;KnightRider/common",  "KnightRider/tracks/instrumental.wav",
StylePtr<Layers<
  Black,
  AlphaL<Red,LinearSectionF<Sin<Int<20>>,Int<5000>>>,
  LockupL<AlphaL<StrobeL<Strobe<Black,White,50,25>,Int<35>,Int<20>>,LinearSectionF<Sin<Int<20>>,Int<5000>>>,AlphaL<StrobeL<Strobe<Black,White,50,25>,Int<35>,Int<20>>,LinearSectionF<Sin<Int<20>>,Int<5000>>>,Int<32768>,Int<32768>,Int<32768>>,
  LockupTrL<AlphaL<StrobeL<Strobe<Black,Mix<TwistAngle<>,Red,Yellow>,50,25>,Int<35>,Int<20>>,LinearSectionF<Sin<Int<20>>,Int<5000>>>,TrInstant,TrFade<300>,SaberBase::LOCKUP_MELT>,
  TransitionEffectL<TrConcat<TrInstant,AlphaL<White,LinearSectionF<Sin<Int<20>>,Int<5000>>>,TrFade<500>>,EFFECT_CLASH>,
  TransitionEffectL<TrConcat<TrInstant,AlphaL<StrobeL<Strobe<Black,White,50,25>,Int<35>,Int<20>>,LinearSectionF<Sin<Int<20>>,Int<5000>>>,TrFade<500>>,EFFECT_STAB>,
  TransitionEffectL<TrConcat<TrInstant,AlphaL<RandomBlink<15000,Red>,LinearSectionF<Sin<Int<20>>,Scale<Trigger<EFFECT_BLAST,Int<100>,Int<500>,Int<800>>,Int<2000>,Int<12000>>>>,TrDelay<1300>>,EFFECT_BLAST>,
  InOutTrL<TrFade<300>,TrFade<300>>>>(),
"K.I.T.T"
{"bank03;bank03/common", "tracks/mandalorian.wav",
  /* copyright Fett263 DarkSaber (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#DarkSaber
OS7.15 v3.218p
This Style Contains 16 Unique Combinations
Style Options:
Default (0): Clone Wars Darksaber
1: Live Action Darksaber (Hyper-Responsive)
Preon Effect Options: Default (0): Disable, 1: Faulty Ignition (Volatile Version) [Color: PreonColorArg]
PowerUp Effect Options: Default (0): Unstable Power Up Forward, 1: Emitter Flash (Preon Size) [Color: IgnitionColorArg]
PostOff Effect Options: Default (0): Disable, 1: Emitter Cool Off (Emitter Size) [Color: PostOffColorArg]
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,AudioFlicker<BrownNoiseFlicker<Mix<SwingSpeed<400>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,White>>,Stripes<5000,-300,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<25700>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,300>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,White>>,Mix<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<2000>,Int<4000>>,Int<8000>>,HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Stripes<35000,-200,Mix<Int<14000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<24000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<28000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,100>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<800>>,TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,AlphaL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<PREON_SIZE_ARG,-31>,Int<-1000>>>,TrFade<1000>>>,EFFECT_IGNITION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Mult<Int<16384>,WavLen<EFFECT_PREON>>,Mult<Int<10922>,WavLen<EFFECT_PREON>>,Mult<Int<5462>,WavLen<EFFECT_PREON>>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<6425>,Black,RotateColorsX<Int<26000>,RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,RotateColorsX<Int<26000>,RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>>>,RotateColorsX<Int<21845>,RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>>,EFFECT_PREON>,TransitionEffectL<TrSelect<IntArg<OFF_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>>,EFFECT_POSTOFF>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<100>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,SmoothStep<VolumeLevel,Int<-1>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
"Din Djarin"
  {"GhostBusters;common", "tracks/Ghostbusters.wav",
/* copyright Fett263 Ghostbusters (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#Ghostbusters
OS7.15 v3.218p
Base Style: Ghostbusters Particle Beam (Original)
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<StaticFire<Mix<SmoothStep<Int<2000>,Int<-2000>>,Stripes<16000,-3900,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>,Mix<Int<8172>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>>,Stripes<2500,-3500,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>,Blue,Mix<Int<16000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>>,DodgerBlue>>,White>,Blue,0,6,1,2000,3>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<100>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>,SmoothStep<VolumeLevel,Int<-1>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
"Ghostbusters"
{"Bank32;common", "tracks/Prism.wav",
/* copyright Fett263 RainbowBlade (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#RainbowBlade
OS7.15 v3.218p
Base Style: Running Rainbow Fire (Fast)
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<StyleFire<Stripes<30000,-100,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RotateColorsX<Int<5461>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RotateColorsX<Int<10922>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RotateColorsX<Int<16384>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RotateColorsX<Int<21845>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RotateColorsX<Int<27306>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,Mix<Int<16384>,Black,Stripes<30000,-100,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RotateColorsX<Int<5461>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RotateColorsX<Int<10922>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RotateColorsX<Int<16384>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RotateColorsX<Int<21845>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RotateColorsX<Int<27306>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>,0,4>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<100>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,SmoothStep<VolumeLevel,Int<-1>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
"Meatball head"
{"bank14;bank14/common", "tracks/jfo3.wav",
  /* copyright Fett263 FallenOrder (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#FallenOrder
OS7.15 v3.43p
This Style Contains 12 Unique Combinations
Base Style: Fallen Order Cal Kestis
Base Color: Kyber Select - BaseColorArg - AltColorArg - AltColor2Arg - AltColor3Arg (0)
Kyber Select Interactive Control: While Blade is On, use Force to change color.
Preon Effect: Pulsing [Color: PreonColorArg]
Ignition Effect Options: Default (0): SparkTip Ignition, 1: Dual Mode Wipe (Down = Fast), 2: Standard Ignition [Color: IgnitionColorArg]
Retraction Effect Options: Default (0): SparkTip Retraction, 1: Dual Mode Wipe In (Down = Fast) [Color: RetractionColorArg]
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
Display Volume: % Blade [Color: BaseColorArg]
StylePtr<Layers<Stripes<16000,-1000,EffectSequence<EFFECT_FORCE,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR3_ARG,Rgb<118,0,194>>>,Pulsing<Mix<Int<11565>,Black,EffectSequence<EFFECT_FORCE,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR3_ARG,Rgb<118,0,194>>>>,EffectSequence<EFFECT_FORCE,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR3_ARG,Rgb<118,0,194>>>,800>,EffectSequence<EFFECT_FORCE,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR3_ARG,Rgb<118,0,194>>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,IgnitionTime<300>,Mult<IgnitionTime<300>,Int<16384>>>>,TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,RetractionTime<0>,Mult<RetractionTime<0>,Int<16384>>>>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<4096>,WavLen<EFFECT_PREON>>>,AlphaL<PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<800>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrDelayX<Mult<Int<28672>,WavLen<EFFECT_PREON>>>>,EFFECT_PREON>,TransitionEffectL<TrSelect<IntArg<OFF_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>>,EFFECT_POSTOFF>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<100>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,SmoothStep<VolumeLevel,Int<-1>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
"Cal Kestis"
{"bank20;common", "tracks/mars.wav",
  /* copyright Fett263 EnergyWeapon (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#EnergyWeapon
OS7.15 v3.43p
Base Style: ElectroStaff
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
Clash Effect: Real Clash V3 [Color: ClashColorArg]
StylePtr<Layers<StaticFire<Strobe<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Strobe<Rgb<100,100,150>,RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Black>,50,1>,100,1>,Mix<Int<6425>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,0,5,2,1000,5>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
"cyber sword"
Preset no_blade[] = {
{ "BalVenos;BalVenos/common",  "tracks/Star Wars Medley (Violin Cover) - Taylor Davis.wav",
StylePtr<Pink>(), "bal venos"},
  { NO_BLADE,
    CONFIGARRAY(no_blade), "no_blade_Save" },
  { 0,
    CONFIGARRAY(blade_in), "blade_in_Save" }
 /* Generated with Fett263 Config Helper v3.11d */
What happened is that it did a blade id scan, which returned 704, which is in your NO_BLADE_ID_RANGE already, so it then added NO_BLADE (which is a billion) to the value.
So it seems like it is correctly detecting that there is no blade detected, at least when you do “scanid”.
So what does the serial monitor say when you connect or disconnect the blade?
the scanid is adding a billion like so with no blade
> scanid
BLADE ID: 1000000768.00
blade = 0
WS2811 Blade with 144 leds.
Style RAM = 8
Scanning sound font: BalVenos
 done
Scanning sound font: BalVenos/common
 done
Activating polyphonic font.
Activating SmoothSwing V2
Accent Swings Enabled.
Polyphonic swings: 18
Monophonic swings: 0
Accent Slashes NOT Detected:
Voice pack version 2 found.
Unmounting SD Card.
Battery voltage: 3.79
with the blade in.
> scanid
BLADE ID: 1000000704.00
blade = 0
Turning off 0.00@0
Turning off 0.00@0
Turning off 0.00@0
Turning off 0.00@0
Turning off 0.00@0
unit = 1 vol = 0.50, Playing BalVenos/in/in01.wav
Style RAM = 8
 done
 done
Ignition.
unit = 0 vol = 0.00, Playing BalVenos/hum01.wav
unit = 1 vol = 0.50, Playing BalVenos/out/out06.wav
humstart: 1800
unit = 2 vol = 0.00, Playing BalVenos/swingl/swingl02.wav
unit = 3 vol = 0.00, Playing BalVenos/swingh/swingh02.wav
Audio underflows: 73
Battery voltage: 3.45
but the presets is only using the 1 blade array, I think it’s because the bladeid hasn’t changed.
Try adding this define:
#define PROFFIEOS_LOG_LEVEL 500
With that it should tell you what the blade ID is every single time.
Battery voltage: 3.61
> scanid
BLADE ID: 719.00
blade = 1
SetPreset(0)
CurrentPreset::Set(0/9)
Style RAM = 2800
ScanIterator . fname=
Directory entry: ‘.’
Directory entry: ‘..’
Directory entry: ‘swingh’
ScanIterator . fname=swingh
Directory entry: ‘swingh03.wav’
SCAN: swingh/swingh03.wav
Directory entry: ‘swingh02.wav’
SCAN: swingh/swingh02.wav
Directory entry: ‘swingh07.wav’
SCAN: swingh/swingh07.wav
Directory entry: ‘swingh05.wav’
SCAN: swingh/swingh05.wav
Directory entry: ‘swingh04.wav’
SCAN: swingh/swingh04.wav
Directory entry: ‘swingh08.wav’
SCAN: swingh/swingh08.wav
Directory entry: ‘swingh01.wav’
SCAN: swingh/swingh01.wav
Directory entry: ‘swingh06.wav’
SCAN: swingh/swingh06.wav
Directory entry: ‘out’
ScanIterator . fname=out
Directory entry: ‘out03.wav’
SCAN: out/out03.wav
Directory entry: ‘out01.wav’
SCAN: out/out01.wav
Directory entry: ‘out05.wav’
SCAN: out/out05.wav
Directory entry: ‘out04.wav’
SCAN: out/out04.wav
Directory entry: ‘out02.wav’
SCAN: out/out02.wav
Directory entry: ‘out06.wav’
SCAN: out/out06.wav
Directory entry: ‘endlock’
ScanIterator . fname=endlock
Directory entry: ‘endlock2.wav’
SCAN: endlock/endlock2.wav
Directory entry: ‘endlock4.wav’
SCAN: endlock/endlock4.wav
Directory entry: ‘endlock1.wav’
SCAN: endlock/endlock1.wav
Directory entry: ‘endlock3.wav’
SCAN: endlock/endlock3.wav
Directory entry: ‘bgnlb’
ScanIterator . fname=bgnlb
Directory entry: ‘bgnlb1.wav’
SCAN: bgnlb/bgnlb1.wav
Directory entry: ‘bgnlb3.wav’
SCAN: bgnlb/bgnlb3.wav
Directory entry: ‘bgnlb2.wav’
SCAN: bgnlb/bgnlb2.wav
Directory entry: ‘quote’
ScanIterator . fname=quote
Directory entry: ‘quote05.wav’
SCAN: quote/quote05.wav
Directory entry: ‘quote07.wav’
SCAN: quote/quote07.wav
Directory entry: ‘quote01.wav’
SCAN: quote/quote01.wav
Directory entry: ‘quote02.wav’
SCAN: quote/quote02.wav
Directory entry: ‘quote06.wav’
SCAN: quote/quote06.wav
Directory entry: ‘quote04.wav’
SCAN: quote/quote04.wav
Directory entry: ‘quote03.wav’
SCAN: quote/quote03.wav
Directory entry: ‘quote08.wav’
SCAN: quote/quote08.wav
Directory entry: ‘swng’
ScanIterator . fname=swng
Directory entry: ‘swng01.wav’
SCAN: swng/swng01.wav
Directory entry: ‘swng06.wav’
SCAN: swng/swng06.wav
Directory entry: ‘swng07.wav’
SCAN: swng/swng07.wav
Directory entry: ‘swng16.wav’
SCAN: swng/swng16.wav
Directory entry: ‘swng02.wav’
SCAN: swng/swng02.wav
Directory entry: ‘swng08.wav’
SCAN: swng/swng08.wav
Directory entry: ‘swng10.wav’
SCAN: swng/swng10.wav
Directory entry: ‘swng04.wav’
SCAN: swng/swng04.wav
Directory entry: ‘swng18.wav’
SCAN: swng/swng18.wav
Directory entry: ‘swng11.wav’
SCAN: swng/swng11.wav
Directory entry: ‘swng17.wav’
SCAN: swng/swng17.wav
Directory entry: ‘swng05.wav’
SCAN: swng/swng05.wav
Directory entry: ‘swng12.wav’
SCAN: swng/swng12.wav
Directory entry: ‘swng03.wav’
SCAN: swng/swng03.wav
Directory entry: ‘swng14.wav’
SCAN: swng/swng14.wav
Directory entry: ‘swng09.wav’
SCAN: swng/swng09.wav
Directory entry: ‘swng15.wav’
SCAN: swng/swng15.wav
Directory entry: ‘swng13.wav’
SCAN: swng/swng13.wav
Directory entry: ‘bgndrag’
ScanIterator . fname=bgndrag
Directory entry: ‘bgndrag3.wav’
SCAN: bgndrag/bgndrag3.wav
Directory entry: ‘bgndrag1.wav’
SCAN: bgndrag/bgndrag1.wav
Directory entry: ‘bgndrag2.wav’
SCAN: bgndrag/bgndrag2.wav
Directory entry: ‘bgnmelt’
ScanIterator . fname=bgnmelt
Directory entry: ‘bgnmelt.wav’
SCAN: bgnmelt/bgnmelt.wav
Directory entry: ‘swingl’
ScanIterator . fname=swingl
Directory entry: ‘swingl07.wav’
SCAN: swingl/swingl07.wav
Directory entry: ‘swingl03.wav’
SCAN: swingl/swingl03.wav
Directory entry: ‘swingl06.wav’
SCAN: swingl/swingl06.wav
Directory entry: ‘swingl01.wav’
SCAN: swingl/swingl01.wav
Directory entry: ‘swingl05.wav’
SCAN: swingl/swingl05.wav
Directory entry: ‘swingl02.wav’
SCAN: swingl/swingl02.wav
Directory entry: ‘swingl08.wav’
SCAN: swingl/swingl08.wav
Directory entry: ‘swingl04.wav’
SCAN: swingl/swingl04.wav
Directory entry: ‘endlb’
ScanIterator . fname=endlb
Directory entry: ‘endlb3.wav’
SCAN: endlb/endlb3.wav
Directory entry: ‘endlb1.wav’
SCAN: endlb/endlb1.wav
Directory entry: ‘endlb2.wav’
SCAN: endlb/endlb2.wav
Directory entry: ‘endmelt’
ScanIterator . fname=endmelt
Directory entry: ‘endmelt.wav’
SCAN: endmelt/endmelt.wav
Directory entry: ‘enddrag’
ScanIterator . fname=enddrag
Directory entry: ‘enddrag6.wav’
SCAN: enddrag/enddrag6.wav
Directory entry: ‘enddrag8.wav’
SCAN: enddrag/enddrag8.wav
Directory entry: ‘enddrag3.wav’
SCAN: enddrag/enddrag3.wav
Directory entry: ‘enddrag1.wav’
SCAN: enddrag/enddrag1.wav
Directory entry: ‘enddrag2.wav’
SCAN: enddrag/enddrag2.wav
Directory entry: ‘enddrag4.wav’
SCAN: enddrag/enddrag4.wav
Directory entry: ‘enddrag5.wav’
SCAN: enddrag/enddrag5.wav
Directory entry: ‘enddrag7.wav’
SCAN: enddrag/enddrag7.wav
Directory entry: ‘force’
ScanIterator . fname=force
Directory entry: ‘force1.wav’
SCAN: force/force1.wav
Directory entry: ‘force2.wav’
SCAN: force/force2.wav
Directory entry: ‘bgnlock’
ScanIterator . fname=bgnlock
Directory entry: ‘bgnlock2.wav’
SCAN: bgnlock/bgnlock2.wav
Directory entry: ‘bgnlock3.wav’
SCAN: bgnlock/bgnlock3.wav
Directory entry: ‘bgnlock1.wav’
SCAN: bgnlock/bgnlock1.wav
Directory entry: ‘stab’
ScanIterator . fname=stab
Directory entry: ‘stab07.wav’
SCAN: stab/stab07.wav
Directory entry: ‘stab08.wav’
SCAN: stab/stab08.wav
Directory entry: ‘stab06.wav’
SCAN: stab/stab06.wav
Directory entry: ‘stab01.wav’
SCAN: stab/stab01.wav
Directory entry: ‘stab04.wav’
SCAN: stab/stab04.wav
Directory entry: ‘stab03.wav’
SCAN: stab/stab03.wav
Directory entry: ‘stab05.wav’
SCAN: stab/stab05.wav
Directory entry: ‘stab02.wav’
SCAN: stab/stab02.wav
Directory entry: ‘clsh’
ScanIterator . fname=clsh
Directory entry: ‘clsh01.wav’
SCAN: clsh/clsh01.wav
Directory entry: ‘clsh13.wav’
SCAN: clsh/clsh13.wav
Directory entry: ‘clsh10.wav’
SCAN: clsh/clsh10.wav
Directory entry: ‘clsh14.wav’
SCAN: clsh/clsh14.wav
Directory entry: ‘clsh05.wav’
SCAN: clsh/clsh05.wav
Directory entry: ‘clsh16.wav’
SCAN: clsh/clsh16.wav
Directory entry: ‘clsh04.wav’
SCAN: clsh/clsh04.wav
Directory entry: ‘clsh12.wav’
SCAN: clsh/clsh12.wav
Directory entry: ‘clsh07.wav’
SCAN: clsh/clsh07.wav
Directory entry: ‘clsh08.wav’
SCAN: clsh/clsh08.wav
Directory entry: ‘clsh02.wav’
SCAN: clsh/clsh02.wav
Directory entry: ‘clsh03.wav’
SCAN: clsh/clsh03.wav
Directory entry: ‘clsh11.wav’
SCAN: clsh/clsh11.wav
Directory entry: ‘clsh09.wav’
SCAN: clsh/clsh09.wav
Directory entry: ‘clsh06.wav’
SCAN: clsh/clsh06.wav
Directory entry: ‘clsh15.wav’
SCAN: clsh/clsh15.wav
Directory entry: ‘in’
ScanIterator . fname=in
Directory entry: ‘in04.wav’
SCAN: in/in04.wav
Directory entry: ‘in01.wav’
SCAN: in/in01.wav
Directory entry: ‘in03.wav’
SCAN: in/in03.wav
Directory entry: ‘in02.wav’
SCAN: in/in02.wav
Directory entry: ‘blst’
ScanIterator . fname=blst
Directory entry: ‘blst05.wav’
SCAN: blst/blst05.wav
Directory entry: ‘blst01.wav’
SCAN: blst/blst01.wav
Directory entry: ‘blst03.wav’
SCAN: blst/blst03.wav
Directory entry: ‘blst06.wav’
SCAN: blst/blst06.wav
Directory entry: ‘blst04.wav’
SCAN: blst/blst04.wav
Directory entry: ‘blst02.wav’
SCAN: blst/blst02.wav
Directory entry: ‘blst08.wav’
SCAN: blst/blst08.wav
Directory entry: ‘blst07.wav’
SCAN: blst/blst07.wav
Directory entry: ‘lowbatt.wav’
SCAN: lowbatt.wav
Directory entry: ‘font.wav’
SCAN: font.wav
Directory entry: ‘preon.wav’
SCAN: preon.wav
Directory entry: ‘boot.bmp’
SCAN: boot.bmp
Directory entry: ‘pstoff.wav’
SCAN: pstoff.wav
Directory entry: ‘smoothsw.ini’
Directory entry: ‘hum01.wav’
SCAN: hum01.wav
Directory entry: ‘melt.wav’
SCAN: melt.wav
Directory entry: ‘config.ini’
Directory entry: ‘LICENSE.txt’
Directory entry: ‘drag.wav’
SCAN: drag.wav
Directory entry: ‘boot.wav’
SCAN: boot.wav
Directory entry: ‘lock01.wav’
SCAN: lock01.wav
Directory entry: ‘choreo.ini’
Directory entry: ‘lb.wav’
SCAN: lb.wav
Directory entry: ‘choreo.tmp’
Directory entry: ‘common’
done
Directory entry: ‘clrlst’
Directory entry: ‘mnum’
ScanIterator . fname=mnum
Directory entry: ‘mnum8.wav’
SCAN: mnum/mnum8.wav
Directory entry: ‘mnum3.wav’
SCAN: mnum/mnum3.wav
Directory entry: ‘mnum13.wav’
SCAN: mnum/mnum13.wav
Directory entry: ‘mnum11.wav’
SCAN: mnum/mnum11.wav
Directory entry: ‘mnum12.wav’
SCAN: mnum/mnum12.wav
Directory entry: ‘mnum5.wav’
SCAN: mnum/mnum5.wav
Directory entry: ‘mnum1.wav’
SCAN: mnum/mnum1.wav
Directory entry: ‘mnum18.wav’
SCAN: mnum/mnum18.wav
Directory entry: ‘mnum19.wav’
SCAN: mnum/mnum19.wav
Directory entry: ‘mnum10.wav’
SCAN: mnum/mnum10.wav
Directory entry: ‘mnum9.wav’
SCAN: mnum/mnum9.wav
Directory entry: ‘mnum16.wav’
SCAN: mnum/mnum16.wav
Directory entry: ‘mnum17.wav’
SCAN: mnum/mnum17.wav
Directory entry: ‘mnum2.wav’
SCAN: mnum/mnum2.wav
Directory entry: ‘mnum6.wav’
SCAN: mnum/mnum6.wav
Directory entry: ‘mnum7.wav’
SCAN: mnum/mnum7.wav
Directory entry: ‘mnum20.wav’
SCAN: mnum/mnum20.wav
Directory entry: ‘mnum14.wav’
SCAN: mnum/mnum14.wav
Directory entry: ‘mnum4.wav’
SCAN: mnum/mnum4.wav
Directory entry: ‘mnum15.wav’
SCAN: mnum/mnum15.wav
Directory entry: ‘mpreopt.wav’
SCAN: mpreopt.wav
Directory entry: ‘forty.wav’
SCAN: forty.wav
Directory entry: ‘mmeltsz.wav’
SCAN: mmeltsz.wav
Directory entry: ‘madjred.wav’
SCAN: madjred.wav
Directory entry: ‘msave.wav’
SCAN: msave.wav
Directory entry: ‘ccend.wav’
SCAN: ccend.wav
Directory entry: ‘mrotate.wav’
SCAN: mrotate.wav
Directory entry: ‘madjgren.wav’
SCAN: madjgren.wav
Directory entry: ‘mpoint.wav’
SCAN: mpoint.wav
Directory entry: ‘macolsty.wav’
SCAN: macolsty.wav
Directory entry: ‘mtrack.wav’
SCAN: mtrack.wav
Directory entry: ‘msetting.wav’
SCAN: msetting.wav
Directory entry: ‘mcolorsb.wav’
SCAN: mcolorsb.wav
Directory entry: ‘mdim.wav’
SCAN: mdim.wav
Directory entry: ‘mswngopt.wav’
SCAN: mswngopt.wav
Directory entry: ‘mrststys.wav’
SCAN: mrststys.wav
Directory entry: ‘mthrston.wav’
SCAN: mthrston.wav
Directory entry: ‘migopt.wav’
SCAN: migopt.wav
Directory entry: ‘mexit.wav’
SCAN: mexit.wav
Directory entry: ‘mbatt.wav’
SCAN: mbatt.wav
Directory entry: ‘mblade.wav’
SCAN: mblade.wav
Directory entry: ‘mpercent.wav’
SCAN: mpercent.wav
Directory entry: ‘mcopy.wav’
SCAN: mcopy.wav
Directory entry: ‘mrtopt.wav’
SCAN: mrtopt.wav
Directory entry: ‘ccchange.wav’
SCAN: ccchange.wav
Directory entry: ‘mrevert.wav’
SCAN: mrevert.wav
Directory entry: ‘mselect.wav’
SCAN: mselect.wav
Directory entry: ‘mpush.wav’
SCAN: mpush.wav
Directory entry: ‘memitsz.wav’
SCAN: memitsz.wav
Directory entry: ‘mretract.wav’
SCAN: mretract.wav
Directory entry: ‘mclick.wav’
SCAN: mclick.wav
Directory entry: ‘mlockup.wav’
SCAN: mlockup.wav
Directory entry: ‘voicepack.ini’
Directory entry: ‘mlockdly.wav’
SCAN: mlockdly.wav
Directory entry: ‘rehrsnew.wav’
SCAN: rehrsnew.wav
Directory entry: ‘stylstm.wav’
SCAN: stylstm.wav
Directory entry: ‘moption.wav’
SCAN: moption.wav
Directory entry: ‘mpwrup.wav’
SCAN: mpwrup.wav
Directory entry: ‘vmend.wav’
SCAN: vmend.wav
Directory entry: ‘mnopsel.wav’
SCAN: mnopsel.wav
Directory entry: ‘msilence.wav’
SCAN: msilence.wav
Directory entry: ‘fifty.wav’
SCAN: fifty.wav
Directory entry: ‘mdelete.wav’
SCAN: mdelete.wav
Directory entry: ‘sixty.wav’
SCAN: sixty.wav
Directory entry: ‘madjsat.wav’
SCAN: madjsat.wav
Directory entry: ‘mstab.wav’
SCAN: mstab.wav
Directory entry: ‘mcancel.wav’
SCAN: mcancel.wav
Directory entry: ‘mpreon.wav’
SCAN: mpreon.wav
Directory entry: ‘mpset.wav’
SCAN: mpset.wav
Directory entry: ‘mtwstoff.wav’
SCAN: mtwstoff.wav
Directory entry: ‘mignite.wav’
SCAN: mignite.wav
Directory entry: ‘mcolorop.wav’
SCAN: mcolorop.wav
Directory entry: ‘maffirm.wav’
SCAN: maffirm.wav
Directory entry: ‘mswingsp.wav’
SCAN: mswingsp.wav
Directory entry: ‘mstabon.wav’
SCAN: mstabon.wav
Directory entry: ‘mzoom.wav’
SCAN: mzoom.wav
Directory entry: ‘mdrag.wav’
SCAN: mdrag.wav
Directory entry: ‘msequent.wav’
SCAN: msequent.wav
Directory entry: ‘bladein.wav’
SCAN: bladein.wav
Directory entry: ‘rehrsbgn.wav’
SCAN: rehrsbgn.wav
Directory entry: ‘mstylsel.wav’
SCAN: mstylsel.wav
Directory entry: ‘msetsub.wav’
SCAN: msetsub.wav
Directory entry: ‘mwhite.wav’
SCAN: mwhite.wav
Directory entry: ‘madjblue.wav’
SCAN: madjblue.wav
Directory entry: ‘mcopyc2.wav’
SCAN: mcopyc2.wav
Directory entry: ‘mgestsub.wav’
SCAN: mgestsub.wav
Directory entry: ‘mtrue.wav’
SCAN: mtrue.wav
Directory entry: ‘mpsetins.wav’
SCAN: mpsetins.wav
Directory entry: ‘bladeout.wav’
SCAN: bladeout.wav
Directory entry: ‘mcolorit.wav’
SCAN: mcolorit.wav
Directory entry: ‘ninety.wav’
SCAN: ninety.wav
Directory entry: ‘mstylopt.wav’
SCAN: mstylopt.wav
Directory entry: ‘mrandom.wav’
SCAN: mrandom.wav
Directory entry: ‘medit.wav’
SCAN: medit.wav
Directory entry: ‘maargsty.wav’
SCAN: maargsty.wav
Directory entry: ‘mmin.wav’
SCAN: mmin.wav
Directory entry: ‘memitter.wav’
SCAN: memitter.wav
Directory entry: ‘minpset.wav’
SCAN: minpset.wav
Directory entry: ‘mmpsetdn.wav’
SCAN: mmpsetdn.wav
Directory entry: ‘maccept.wav’
SCAN: maccept.wav
Directory entry: ‘mmpsetbg.wav’
SCAN: mmpsetbg.wav
Directory entry: ‘mmax.wav’
SCAN: mmax.wav
Directory entry: ‘mmpsetup.wav’
SCAN: mmpsetup.wav
Directory entry: ‘maxclash.wav’
SCAN: maxclash.wav
Directory entry: ‘mmpset.wav’
SCAN: mmpset.wav
Directory entry: ‘a_ReadMe.txt’
Directory entry: ‘mclash.wav’
SCAN: mclash.wav
Directory entry: ‘mgestoff.wav’
SCAN: mgestoff.wav
Directory entry: ‘mclashth.wav’
SCAN: mclashth.wav
Directory entry: ‘rehrsend.wav’
SCAN: rehrsend.wav
Directory entry: ‘mzero.wav’
SCAN: mzero.wav
Directory entry: ‘mcolor.wav’
SCAN: mcolor.wav
Directory entry: ‘mstyle.wav’
SCAN: mstyle.wav
Directory entry: ‘mvolts.wav’
SCAN: mvolts.wav
Directory entry: ‘mcopyc.wav’
SCAN: mcopyc.wav
Directory entry: ‘volmax.wav’
SCAN: volmax.wav
Directory entry: ‘mcooldwn.wav’
SCAN: mcooldwn.wav
Directory entry: ‘moptnum.wav’
SCAN: moptnum.wav
Directory entry: ‘msdacc.wav’
SCAN: msdacc.wav
Directory entry: ‘mfalse.wav’
SCAN: mfalse.wav
Directory entry: ‘million.wav’
SCAN: million.wav
Directory entry: ‘thousand.wav’
SCAN: thousand.wav
Directory entry: ‘mbld.wav’
SCAN: mbld.wav
Directory entry: ‘mgeston.wav’
SCAN: mgeston.wav
Directory entry: ‘chreoend.wav’
SCAN: chreoend.wav
Directory entry: ‘mpwrlock.wav’
SCAN: mpwrlock.wav
Directory entry: ‘eighty.wav’
SCAN: eighty.wav
Directory entry: ‘mstylnum.wav’
SCAN: mstylnum.wav
Directory entry: ‘migdelay.wav’
SCAN: migdelay.wav
Directory entry: ‘mpstofsz.wav’
SCAN: mpstofsz.wav
Directory entry: ‘mpreonsz.wav’
SCAN: mpreonsz.wav
Directory entry: ‘macolall.wav’
SCAN: macolall.wav
Directory entry: ‘mintime.wav’
SCAN: mintime.wav
Directory entry: ‘mswingon.wav’
SCAN: mswingon.wav
Directory entry: ‘mdragsz.wav’
SCAN: mdragsz.wav
Directory entry: ‘thirty.wav’
SCAN: thirty.wav
Directory entry: ‘mrtdelay.wav’
SCAN: mrtdelay.wav
Directory entry: ‘mblack.wav’
SCAN: mblack.wav
Directory entry: ‘volmin.wav’
SCAN: volmin.wav
Directory entry: ‘mtwiston.wav’
SCAN: mtwiston.wav
Directory entry: ‘mauto.wav’
SCAN: mauto.wav
Directory entry: ‘mseconds.wav’
SCAN: mseconds.wav
Directory entry: ‘mnostsel.wav’
SCAN: mnostsel.wav
Directory entry: ‘mlockpos.wav’
SCAN: mlockpos.wav
Directory entry: ‘mdown.wav’
SCAN: mdown.wav
Directory entry: ‘mstylesb.wav’
SCAN: mstylesb.wav
Directory entry: ‘battlevl.wav’
SCAN: battlevl.wav
Directory entry: ‘vmbegin.wav’
SCAN: vmbegin.wav
Directory entry: ‘mseting2.wav’
SCAN: mseting2.wav
Directory entry: ‘chreobgn.wav’
SCAN: chreobgn.wav
Directory entry: ‘voldown.wav’
SCAN: voldown.wav
Directory entry: ‘meffect.wav’
SCAN: meffect.wav
Directory entry: ‘mvolume.wav’
SCAN: mvolume.wav
Directory entry: ‘mmain.wav’
SCAN: mmain.wav
Directory entry: ‘mlength.wav’
SCAN: mlength.wav
Directory entry: ‘mswing.wav’
SCAN: mswing.wav
Directory entry: ‘a_Huyang.jpg’
Directory entry: ‘volup.wav’
SCAN: volup.wav
Directory entry: ‘mcantdlp.wav’
SCAN: mcantdlp.wav
Directory entry: ‘mpushlen.wav’
SCAN: mpushlen.wav
Directory entry: ‘mpastec.wav’
SCAN: mpastec.wav
Directory entry: ‘mpstoff.wav’
SCAN: mpstoff.wav
Directory entry: ‘mmillis.wav’
SCAN: mmillis.wav
Directory entry: ‘mup.wav’
SCAN: mup.wav
Directory entry: ‘mouttime.wav’
SCAN: mouttime.wav
Directory entry: ‘malt.wav’
SCAN: malt.wav
Directory entry: ‘ccbegin.wav’
SCAN: ccbegin.wav
Directory entry: ‘mstnoset.wav’
SCAN: mstnoset.wav
Directory entry: ‘nochreo.wav’
SCAN: nochreo.wav
Directory entry: ‘mloop.wav’
SCAN: mloop.wav
Directory entry: ‘mbmclash.wav’
SCAN: mbmclash.wav
Directory entry: ‘medpsets.wav’
SCAN: medpsets.wav
Directory entry: ‘mresetc.wav’
SCAN: mresetc.wav
Directory entry: ‘mlb.wav’
SCAN: mlb.wav
Directory entry: ‘moff.wav’
SCAN: moff.wav
Directory entry: ‘mstylset.wav’
SCAN: mstylset.wav
Directory entry: ‘mcontrol.wav’
SCAN: mcontrol.wav
Directory entry: ‘mblast.wav’
SCAN: mblast.wav
Directory entry: ‘mbase.wav’
SCAN: mbase.wav
Directory entry: ‘hundred.wav’
SCAN: hundred.wav
Directory entry: ‘mfont.wav’
SCAN: mfont.wav
Directory entry: ‘mbuzz.wav’
SCAN: mbuzz.wav
Directory entry: ‘mpreset.wav’
SCAN: mpreset.wav
Directory entry: ‘mconfirm.wav’
SCAN: mconfirm.wav
Directory entry: ‘moffopt.wav’
SCAN: moffopt.wav
Directory entry: ‘mhue.wav’
SCAN: mhue.wav
Directory entry: ‘mcolrst.wav’
SCAN: mcolrst.wav
Directory entry: ‘seventy.wav’
SCAN: seventy.wav
Directory entry: ‘mnoselcl.wav’
SCAN: mnoselcl.wav
Directory entry: ‘rehrsold.wav’
SCAN: rehrsold.wav
done
Unmounting SD Card.
the blade id seems to be under 1000 regardless of the blade being in or out.
Do you have an ID resistor in your blade?
Do you have Neopixels in the hilt connected in parallel with the blade?
It’s obviously going to be hard for ProffieOS to tell the two apart if they end up with the same ID.
i think the answers to that are no and no. but I reverted back to no bladeid. I am getting a weird behaviour creating new presets but I’ll raise that somewhere else.
Unfortunately, SnapshotBladeID isn’t very predictable because it measures a combination of resistance and capacitance. What that means is that sometimes two blades (or a blade and no blade) comes out with similar values, and it’s not easy to tell them apart. In cases like this you need a resistor in the blade and/or a pullup resistor in the hilt (which can be done by briding to another pad on the proffieboard.) to get more reasonable values.
That said, it’s fairly unusual for “no blade” to come out with the same value as a blade, so I’m wondering if there is a reason for that…
Does your hilt-side pcb have leds and how is it wired? Scrolling up and looking at your blade definition, it looks like it’s either in series or more likely in parallel, both will alter the blade id scan. the only way to get reliable and consistent blade id’s is with the hilt-side pcb wired independently. It can work, but it won’t be consistent.
