It produces a slowly building cyan blade on ignition. Odd thing is: after a retract, the next ignition just produces a cyan blade lighting up all at once. If I chose a different blade and then go back to this one it produces a slow build again.
You need to change the time to transition or allow it to complete. ColorCycle<> has ON and OFF states built in if you ignite while is still transitioning it will not have returned to original starting speed thereby affecting what you see.
If you want similar effect you can just apply a TrColorCycle ignition effect it will reset each transition instead.
It has to finish transitioning from ON to OFF, so however long you set (default is 5000 ms I think if you didn’tset in template), then it would be back to original speed for you to ignite the same way, if you ignite before that it is starting at a different speed.
Ok. But I can wait much longer than 5000ms, in fact an hour, and when i reignite it doesnt transition. The only way to reset is to chose another blade style and then change back.
