You can add the following define to change the hold time for power off:
#define BUTTON_HELD_LONG_TIMEOUT 1500
If you want to make it shorter than 1000 you might need to change the medium time as well:
#define BUTTON_HELD_MEDIUM_TIMEOUT 1000
As for the extension and retraction times, you can find them at the end of your style:
InOutTrL<TrWipe<300>,TrWipeIn<500>>
You can change these to something smaller to make it ignite/retract faster.
You may also want to consider writing your style like this to make it easier to read:
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,200,0>>>,
AlphaL<NavajoWhite,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveStabL<Red>,
SimpleClashL<White>,
InOutTrL<TrWipe<300>,TrWipeIn<500>>>>()
