- Yes and yes.
- Yes.
If you mean 8.x, then yes.
If you mean 7.11, then no.
(This is new features, not bugfixes, so it will not be merged into 7.x)
Cool. I’ll be looking forward to ProffieOS8 ![]()
Well, this was unexpected.
I have USB in with Serial Moitor open.
Adding / removing my kill key is triggering different values for blade ID, therefore doing bladein/bladeout.
I have to assume it has to do with the read calculations and the Battery power compared to USB power affecting the math.
I think that actually makes sense.
Without battery power, the neopixels won’t be powered, and without power, the data line sucks up power like a sponge, which affects the readout.
When the blade pixels are properly powered, their input is in high impedance (resistance) mode, which should affect the readings very little.
Cool.
Having LED2&3 line fall off in the chassis mashing also contributed probably!
