Blade ID for Chassis Detect using NPXL Eco
so ive just bought a hilt with a install kit and it comes with a NPXL v4 eco (no BD pin) and v3 board, the chassis is removable and i am wanting it to play the blade in/out sounds when it makes contact with the in hilt NPXL pcb, I’ve been researching it all day trying to get my head around it using blade id. ive read that when using a v3 board i wont need to add a resistor to the data line because there is one all ready build into d1, I’ve not started the wiring yet so cant test it physically so I’m just seeing if I’ve got the config correct.
this is the config i have come up with
// Valley Forged
#define NUM_BLADES 3
#define MOUNT_SD_SETTING
#define BOOT_VOLUME 1200
#define VOLUME 3000
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define ENABLE_SPINS
#define ENABLE_IDLE_SOUND
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define SHARED_POWER_PINS
#define BLADE_ID_TIMES 10
#define ENABLE_POWER_FOR_ID PowerPINS<bladePowerPin2,bladePowerPin3>
#define FETT263_SPIN_MODE
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
#define FETT263_TWIST_ON
  { "Kyle;common", "tracks/track1.wav",
//main blade
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,60>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,0>>,Bump<Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>>,AlphaL<Remap<CenterDistF<Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>>,Stripes<1400,-2000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<2096>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,0>>>>>,Bump<Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>,Int<38000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,0>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,0>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,0>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,0>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
// accents
StylePtr<Layers<Mix<LinearSectionF<Saw<Int<200>>,Int<3000>>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,TransitionLoop<Black,TrConcat<TrCenterWipe<500>,RgbArg<OFF_COLOR_ARG,Rgb<0,255,0>>,TrCenterWipe<500>>>>>>(),
// crystal chamber
StylePtr<Layers<AudioFlicker<Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,3000>,Mix<Int<10560>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,Pulsing<Black,RgbArg<OFF_COLOR_ARG,Rgb<0,0,255>>,2000>>>>(),"Kyle"}, //blue
  { "Luke;common", "tracks/track1.wav",
//main blade
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,60>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,0>>,Bump<Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>>,AlphaL<Remap<CenterDistF<Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>>,Stripes<1400,-2000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<2096>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,0>>>>>,Bump<Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>,Int<38000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,0>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,0>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,0>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,0>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RotateColorsX<Int<4096>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
// accents
// crystal chamber
StylePtr<Layers<AudioFlicker<Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,3000>,Mix<Int<10560>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,Pulsing<Black,RgbArg<OFF_COLOR_ARG,Rgb<0,255,0>>,2000>>>>(),"Luke"}, //green
Preset no_blade_presets[] = {
//main blade
// accents
// crystal chamber
  "no blade" },
 { 5000, WS281XBladePtr<144, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), //main blade
      WS281XBladePtr<10, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin5> >(),                 //accents
      WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),                  //crystal chamber
      CONFIGARRAY(presets) },
{ NO_BLADE, WS281XBladePtr<144, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), //main blade
      CONFIGARRAY(no_blade_presets), "nb_save" },
will this config work for what i need and do i need to do anything with the wiring side of things
I don’t use BladeID much, but it basically works by measuring a resistance between the data pin and the blade negative. So in your case, you would need to add a resistor between those two on the part that stays in the hilt. Then when you insert the chassis, the Proffie registers that resistance and recognises the change.
You need to use quite high values - 20,000 ohms or something like that. And the number you add to the blade array (in your config you have it down as 5000) needs to be based on what the Proffie reads from that resistor.
You might also want to try this define:
#define BLADE_ID_CLASS ExternalPullupBladeID<bladeIdentifyPin, 22000>
instead of:
as you should be able to enter roghly the value of the resistor in that number field in the blades array.
As I say it’s been a while since I had a play around with BladeID, but I believe that’s how it should work.
So to answer your final question, yes you will need to do a little wiring on the front section of the hilt to add that resistor.
So I’ll pop a 20k resistor from the data pad to the blade neg pad on Npxl pcb, swap out them defines and change the values in the blade array :+1:t2:, this will be my mission today, been itching to build It but needed to double check everything was correct, Thanks for the help man it’s must appreciated
Sorry if this sounds like a stupid question but will adding a resistor between them two not bridge them? Just cause after soldering just the wires on and testing for shorts there’s no continuity between the data and the negative.
I think it depends on how your test meter defines ‘continuity’. Yes it does bridge them, but with lots of resistance in between, so it’s not a short as such. At least that’s as I understand it.
Put succinctly, all electronics work by connecting positive and negative together to have power flow, then doing something useful with that power flow. The problem with a short is that it describes a very low resistance connection. If the only thing limiting power flow (where you’ve a battery/power source where the positive and negative would really like to reach equilibrium) is that low resistance path, you’re inviting massive current, so massive power, so massive heat loss, and all of a sudden there’s maybe a little fire, probably some smoke, and a little bit less of a connection (it blew/burned up).
Of course, a resistor’s job is to be a (relatively) high-resistance connection, so very little power flows.
My notes on BladeID:
// #define BLADE_ID_CLASS ExternalPullupBladeID<bladeIdentifyPin, 33000> // resistor value used
// BridgedPullupBladeID is the default Proffieboard V3 BLADE_ID_CLASS, so it doesn’t need to defined explicitly with a V3.
// #define BLADE_ID_CLASS BridgedPullupBladeID<bladeIdentifyPin, 9> // PBv2.2 TX pad for example
/* SnapshotBladeID is the default Proffieboard V1.5 and V2.2 BLADE_ID_CLASS, so it doesn’t need to defined explicitly.
It will make it use the speed-of-charging-a-capacitor method of blade ID which sometimes works without resistors.
Blade ID can detect if a blade is connected or not, but it won’t actually reach the NO_BLADE value,
so using something like 200000 instead of NO_BLADE is best. */
// #define BLADE_ID_CLASS SnapshotBladeID
– Real Time BladeID –
Main blade must be wired to data1
Blades can use the same set of presets, or have a Presets array for each blade.
Arrays should be named differently like no_blade, blade_1, blade_2, etc…
Match Preset array names names to the CONFIGARRAY for the given blade.
Open Serial Monitor in Arduino and type id to read the resistance value.
It will display “BLADE ID: (some number)”
Use that value in the blade definition in the BladeConfig.
  • Note * It is recommended to use a Blade ID resistor in each blade
    to ensure different and distant enough resistance values between blades.
    However, in testing, values reported for a chassis alone,
    chassis inserted into the hilt (connected to emitter PCB)
    and then main blade inserted all gave different enough values on their own
    without added resistors and it worked fine. YMMV.
// Use with Blade ID. Specify the LED pad(s) that the main blade uses.
// #define ENABLE_POWER_FOR_ID PowerPINS<bladePowerPin2, bladePowerPin3>
// Required when blades on different data pads use common LED power pads.
// and/or when BLADE_ID_SCAN_MILLIS is used with Blade ID.
// #define SHARED_POWER_PINS
// Choose how often to check for new blade (milliseconds).
// Larger values will be a longer delay before a blade is recognized.
// #define BLADE_ID_SCAN_MILLIS 1000
// How many Blade ID scans to average (default is 10, works well)
// #define BLADE_ID_TIMES 15
// This will make the blade ID class for that range return NO_BLADE (use NO_BLADE as the blade definition value.)
// #define NO_BLADE_ID_RANGE 15000,99999999
// This define allows you to set a timeout on how long active blade scanning will actually be active for.
// Similar to IDLE_OFF_TIME, but just for the continous blade ID scan.
//#define BLADE_ID_SCAN_TIMEOUT 5 * 60 * 1000
// This define stops ID scanning while the saber is ignited.
// With no scanning there is no chance of getting the ID wrong and re-initialize the saber while using it.
//#define BLADE_ID_STOP_SCAN_WHEN_IGNITED
// Show blade ID value every BLADE_ID_SCAN_MILLIS
// SEE #define PROFFIEOS_LOG_LEVEL 500
// Requires wiring a pad to a switched GND
// (floating pogo pin until grounded via blade-side PCB ring)
// #define BLADE_DETECT_PIN 10
@Aaron_Hilditch before you add any resistors, you might take a look at what your readings are. First, you can remove your BLADE_ID_CLASS since you don’t need SnapshotBladeID on a v3 which already defaults to BridgedPullupBladeID. OS8 adds the NO_BLADE_ID_RANGE that will give you exactly what you’re looking for. After you flash that change, connect to a serial monitor and run scanid to determine your chassis out value. This should be pretty high (a recent build of mine was about 730k).
Assuming you can get serial connection while chassis is in hilt you do a scanid and find that value, but it will be much much less so won’t really matter if you are only going to use blade detect as your chassis in/out (my value was about 55k on that build). You can then set your NO_BLADE_ID_RANGE to something between your two values close with a buffer to your chassis removed value. Anything inside this defined range gets the 1B added to the value so is closest to your NO_BLADE blade config. And 0 is fine for your main blade as you have it. I also like to use the define for stopping scans while ignited since I’ve found it more stable and don’t need a blade change while ignited. So your updated section might look like this:
// ------------ Blade Detect & ID Monitoring ------------
#define SHARED_POWER_PINS                      	// Lets two blades, or Blade ID and a blade, share a power pin
#define NO_BLADE_ID_RANGE 200000,999999999       // ID reading range interpreted as "no blade"
#define BLADE_ID_SCAN_MILLIS 500              	// Interval between automatic Blade ID scans (ms)
#define BLADE_ID_TIMES 10                      	// Number of samples averaged for each ID scan
#define ENABLE_POWER_FOR_ID PowerPINS<bladePowerPin2, bladePowerPin3> // Power blade during ID read for stable measurement
#define BLADE_ID_STOP_SCAN_WHILE_IGNITED         // Disable ID scanning while blade is ignite
If you’re interested in doing more and having blade detect and chassis detect (with no resistors), you can check out my add-ons. But even without all that, you should be able to get what you were asking for. Mine looks like this with 2 different blade id values and the NO_BLADE.
#define JMT_SWING_ON_BLOCK                    	// Blocks swing on ignition when no blade is installed
#define JMT_BLADE_DETECT						    // Use the JMT Blade Detect method to include Blade Detect features on Blade ID
#define NO_BLADE_ID_RANGE 22000,999999999       	// ID reading range interpreted as "no blade"
#define BLADE_ID_STOP_SCAN_WHILE_IGNITED         // Disable ID scanning while blade is ignited
// ------------ Chassis Detect ------------
#define JMT_CHASSIS_DETECT_RANGE 200000, 1000000  // BladeID resistance read as chassis OUT
#define JMT_ROLL_PRESETS                          // Roll through presets while horizontal and chassis out
#define JMT_CHASSIS_WAKE                          // Wake saber on insert/removal of chassis
// JMT Octocore 33" Blade
{ 5000,
WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<22, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin1>>(),
DimBlade(30, SubBladeReverse(0, 43, WS281XBladePtr<44, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin5>>())),
// General 34" Blade
{ 19000,
// NPXL Connector Active (Blade Removed)
{ NO_BLADE,
SubBladeWithList<0,2,4,6,8,10,12,14, 1,3,5,7,9,11,13,15>(WS281XBladePtr<16, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
CONFIGARRAY(presets),
thanks man thats great, i can screw the hilt in half to be able to get a reading while inserted, im gonna have a play around with it now and see what im dealing with
Doesn’t the ECO pogo pin PCB have some pixels that are connected in parallel with the blade? If so, that makes it much harder to blade ID since we’ll see the resistance of the in-hilt pixels all the time. I think it will still work, just be aware that it can cause issues.
I didn’t end up using a resistor so i could’nt get what i was looking for in regards to chassis detect without a blade, what I’ve ended up with is blade detect without a dedicated pin, if there is a led blade plug or a blade connected when i insert the chassis it plays the bladein/out sounds, i can live with that only cause i don’t wanna start de-soldering and messing about, ive learnt from it for any future builds,
