Hey, I am setting up my Darth Vader mpp lightsaber to have the blade styles and colors from the original trilogy using the hyperactive rotoscoping. What movie accurate rgb color codes do you all use for each of the 3 movies? Thanks
His is just red.
Although the true 255, 0, 0 is a good start, the consensus is usually that it’s subjective. So you can start with red, go into color select and color zoom and dial it in as you see it. It’s different on various media set ups (tv, hd, real film). The way you sand your blades, even the manufacturing runs of various pixel strips, all play into how it looks overall.
