Bad Gyro?
Got an 89 Sabers installed hilt in for repair, and I’ve sorted the thing that was broken, but firing it up, there are no swing sounds. Ignition, idle hum, clash etc. all work - just no swings.
Done the usual - reload SD card, load new config etc., but no difference.
Serial monitor gives the figures below with monitor gyro. There doesn’t seem to be any appreciable difference in gyro numbers between the hilt being still and it being swung around, which I’m guessing means the gyro is kaput and a new board is in order?
Just thought I’d check in with the Crucible Oracles here first before I go any further.
Thanks as always.
:slight_smile:
18:00:39.902 -> Welcome to ProffieOS ProffieOS 7.13. 89 Sabers Blue.
18:00:39.902 -> For available serial commands, see:
18:00:39.902 -> https://pod.hubbe.net/tools/serial-monitor-commands.html
18:00:45.648 -> GYRO: 24.05, -125.19, -34.96
18:00:45.862 -> GYRO: 24.36, -125.57, -35.09
18:00:46.066 -> GYRO: 24.86, -125.95, -35.06
18:00:46.245 -> GYRO: 25.29, -126.63, -35.16
18:00:46.462 -> GYRO: 25.55, -126.81, -35.19
18:00:46.671 -> GYRO: 26.09, -127.32, -35.29
18:00:46.851 -> GYRO: 25.00, -126.17, -35.24
18:00:47.064 -> GYRO: 25.00, -126.43, -35.17
18:00:47.270 -> GYRO: 24.35, -125.59, -35.23
18:00:47.447 -> GYRO: 25.48, -126.81, -35.35
18:00:47.658 -> GYRO: 24.48, -125.91, -35.37
18:00:47.869 -> GYRO: 25.59, -126.68, -35.50
18:00:48.055 -> GYRO: 24.39, -125.76, -35.21
18:00:48.267 -> GYRO: 25.57, -126.78, -35.46
18:00:48.483 -> GYRO: 24.53, -125.72, -35.17
18:00:48.659 -> GYRO: 24.27, -125.40, -35.24
18:00:48.869 -> GYRO: 25.01, -126.60, -36.04
18:00:49.076 -> GYRO: 23.84, -125.93, -33.19
18:00:49.286 -> GYRO: 21.77, -123.87, -34.19
18:00:49.463 -> GYRO: 24.55, -127.08, -33.36
18:00:49.670 -> GYRO: 26.50, -130.16, -41.26
18:00:49.887 -> GYRO: 24.25, -125.59, -28.73
18:00:50.034 -> Battery voltage: 3.30
18:00:50.068 -> GYRO: 25.45, -125.06, -28.61
18:00:50.281 -> GYRO: 26.73, -130.61, -42.38
18:00:50.470 -> GYRO: 24.81, -127.63, -35.35
18:00:50.683 -> GYRO: 23.72, -123.66, -27.71
18:00:50.864 -> GYRO: 24.47, -124.56, -34.53
18:00:51.078 -> GYRO: 26.35, -130.49, -36.73
18:00:51.292 -> GYRO: 25.27, -127.00, -35.83
18:00:51.473 -> GYRO: 23.58, -122.28, -27.79
18:00:51.688 -> GYRO: 24.15, -124.11, -33.89
18:00:51.896 -> GYRO: 26.96, -130.62, -41.35
18:00:52.068 -> GYRO: 26.66, -130.55, -39.76
18:00:52.282 -> GYRO: 22.41, -122.43, -29.86
18:00:52.468 -> GYRO: 24.46, -125.55, -33.84
18:00:52.677 -> GYRO: 24.36, -126.58, -36.25
18:00:52.888 -> GYRO: 25.71, -127.32, -36.10
18:00:53.101 -> GYRO: 25.61, -126.87, -35.50
18:00:53.282 -> GYRO: 24.99, -125.98, -34.89
18:00:53.485 -> GYRO: 24.98, -126.14, -35.18
18:00:53.698 -> GYRO: 24.79, -125.71, -35.61
18:00:53.880 -> GYRO: 24.87, -126.06, -35.72
18:00:54.088 -> GYRO: 25.03, -126.21, -35.46
18:00:54.304 -> GYRO: 25.69, -126.79, -35.11
18:00:54.484 -> GYRO: 25.21, -126.22, -35.10
18:00:54.691 -> GYRO: 24.96, -126.15, -35.27
18:00:54.906 -> GYRO: 24.39, -125.38, -35.50
18:00:54.940 -> EVENT: Power-Pressed#1 millis=64894
18:00:54.940 -> EVENT: Power-Pressed millis=64894
18:00:55.088 -> EVENT: Power-Released#1 millis=65043
18:00:55.088 -> EVENT: Power-Released millis=65043
18:00:55.088 -> EVENT: Power-Shortclick#1 millis=65043
18:00:55.088 -> EVENT: Power-Shortclick millis=65044
18:00:55.088 -> GYRO: 25.40, -126.65, -35.13
18:00:55.230 -> EVENT: Power-SavedShortclick#1 millis=65195
18:00:55.230 -> Ignition.
18:00:55.266 -> unit = 0 vol = 0.00, Playing Graflex/hum01.wav
18:00:55.266 -> channels: 1 rate: 44100 bits: 16
18:00:55.266 -> unit = 1 vol = 0.50, Playing Graflex/out05.wav
18:00:55.266 -> humstart: 1800
18:00:55.266 -> unit = 2 vol = 0.00, Playing Graflex/swingl03.wav
18:00:55.266 -> unit = 3 vol = 0.00, Playing Graflex/swingh03.wav
18:00:55.301 -> GYRO: 25.21, -126.29, -35.61
18:00:55.516 -> GYRO: 24.88, -125.79, -35.57
18:00:55.726 -> GYRO: 24.98, -126.07, -34.63
18:00:55.903 -> GYRO: 25.40, -126.50, -34.00
18:00:56.116 -> GYRO: 24.67, -125.92, -33.84
18:00:56.337 -> GYRO: 24.62, -125.76, -34.86
18:00:56.513 -> GYRO: 24.76, -126.09, -35.30
18:00:56.726 -> GYRO: 25.72, -127.83, -44.59
18:00:56.936 -> GYRO: 26.19, -127.66, -38.71
18:00:57.118 -> GYRO: 23.86, -125.13, -25.77
18:00:57.324 -> GYRO: 26.42, -125.88, -29.63
18:00:57.537 -> GYRO: 26.05, -128.52, -40.25
18:00:57.748 -> GYRO: 26.90, -129.04, -44.04
18:00:57.928 -> GYRO: 24.93, -125.97, -30.59
18:00:58.136 -> GYRO: 25.81, -124.93, -28.35
18:00:58.356 -> GYRO: 25.69, -126.89, -36.33
18:00:58.530 -> GYRO: 26.27, -129.72, -33.02
18:00:58.746 -> GYRO: 23.28, -122.99, -37.28
18:00:58.927 -> GYRO: 25.78, -125.97, -32.10
18:00:59.137 -> GYRO: 25.76, -128.38, -45.50
18:00:59.348 -> GYRO: 26.19, -127.76, -38.83
18:00:59.558 -> GYRO: 24.95, -124.01, -19.85
18:00:59.728 -> GYRO: 25.94, -125.94, -33.59
18:00:59.939 -> GYRO: 26.53, -128.76, -49.79
18:01:00.151 -> GYRO: 24.46, -123.77, -22.38
18:01:00.336 -> GYRO: 24.77, -127.10, -40.15
18:01:00.557 -> GYRO: 24.19, -124.44, -29.26
18:01:00.739 -> GYRO: 26.04, -128.71, -42.98
18:01:00.947 -> GYRO: 24.63, -124.31, -26.50
18:01:01.159 -> GYRO: 25.36, -125.99, -33.77
18:01:01.340 -> GYRO: 27.65, -130.01, -45.36
18:01:01.551 -> GYRO: 24.16, -123.72, -28.44
18:01:01.765 -> GYRO: 24.64, -126.76, -35.65
18:01:01.946 -> GYRO: 24.57, -126.00, -34.20
18:01:02.165 -> GYRO: 25.86, -126.63, -34.99
18:01:02.346 -> GYRO: 27.19, -127.67, -35.30
18:01:02.564 -> GYRO: 25.29, -126.40, -35.39
18:01:02.774 -> GYRO: 24.82, -126.10, -34.69
18:01:02.946 -> GYRO: 25.08, -126.07, -35.34
18:01:03.157 -> GYRO: 26.29, -127.04, -35.74
18:01:03.268 -> EVENT: Power-Pressed#1 ON millis=73251
18:01:03.268 -> EVENT: Power-Pressed ON millis=73251
18:01:03.268 -> Playing Graflex/swingl03.wav
18:01:03.268 -> channels: 1 rate: 44100 bits: 16
18:01:03.373 -> GYRO: 26.32, -127.09, -35.64
18:01:03.480 -> EVENT: Power-Released#1 ON millis=73450
18:01:03.480 -> EVENT: Power-Released ON millis=73450
18:01:03.480 -> EVENT: Power-Shortclick#1 ON millis=73450
18:01:03.480 -> EVENT: Power-Shortclick ON millis=73450
18:01:03.581 -> GYRO: 25.42, -126.50, -34.56
18:01:03.581 -> EVENT: Power-SavedShortclick#1 ON millis=73552
18:01:03.581 -> EVENT: Power-SavedShortclick ON millis=73552
18:01:03.757 -> GYRO: 25.71, -126.66, -35.33
18:01:03.969 -> GYRO: 25.22, -126.51, -35.06
18:01:04.192 -> GYRO: 25.29, -126.51, -35.17
18:01:04.373 -> GYRO: 25.01, -125.76, -34.90
18:01:04.588 -> GYRO: 25.32, -126.32, -35.05
18:01:04.727 -> EVENT: Power-Pressed#1 ON millis=74689
18:01:04.727 -> EVENT: Power-Pressed ON millis=74689
18:01:04.761 -> GYRO: 25.49, -126.35, -35.46
18:01:04.980 -> GYRO: 25.87, -126.75, -35.26
18:01:05.014 -> EVENT: Power-Held#1 ON millis=74990
18:01:05.014 -> EVENT: Power-Held ON millis=74990
18:01:05.191 -> GYRO: 26.43, -127.43, -35.37
18:01:05.367 -> GYRO: 27.00, -127.87, -35.41
18:01:05.579 -> GYRO: 26.12, -126.98, -35.33
18:01:05.730 -> EVENT: Power-HeldMedium#1 ON millis=75690
18:01:05.730 -> unit = 1 vol = 0.50, Playing Graflex/in01.wav
18:01:05.730 -> channels: 1 rate: 44100 bits: 16
18:01:05.802 -> GYRO: 26.00, -126.89, -35.29
18:01:05.979 -> GYRO: 25.95, -126.94, -35.24
18:01:06.154 -> EVENT: Power-Released#1 millis=76142
18:01:06.154 -> EVENT: Power-Released millis=76142
18:01:06.192 -> GYRO: 26.62, -127.78, -35.12
18:01:06.400 -> GYRO: 25.04, -126.03, -35.21
18:01:06.578 -> GYRO: 25.60, -126.29, -35.64
18:01:06.760 -> No sounds found: pstoff
18:01:06.795 -> GYRO: 25.71, -126.53, -35.80
18:01:06.795 -> Amplifier off.
18:01:06.973 -> GYRO: 25.91, -126.52, -36.96
18:01:07.192 -> GYRO: 27.07, -126.97, -39.22
18:01:07.404 -> GYRO: 25.88, -126.39, -36.33
18:01:07.589 -> GYRO: 25.43, -125.85, -35.40
18:01:07.764 -> Unmounting SD Card.
18:01:07.764 -> EVENT: Clash millis=77739
18:01:07.802 -> GYRO: 26.55, -127.34, -36.21
18:01:07.979 -> GYRO: 26.01, -126.45, -34.90
18:01:08.197 -> GYRO: 24.63, -125.82, -35.08
18:01:08.405 -> GYRO: 24.97, -126.56, -35.30
18:01:08.591 -> GYRO: 24.91, -126.04, -35.28
18:01:08.805 -> GYRO: 26.60, -127.55, -35.41
18:01:09.014 -> GYRO: 25.49, -126.69, -35.36
18:01:09.188 -> GYRO: 25.14, -126.09, -35.20
18:01:09.394 -> GYRO: 25.42, -126.62, -35.23
18:01:09.612 -> GYRO: 26.31, -127.05, -35.28
Indeed, values like that means the gyro is not working.
Unless you want to actually replace the motion chip, then yes, a new board is required.
Thanks Prof. Thought so.
I think replacing the chip will end up as more work than it’s worth, so I’ll tell the guy new board and see what he wants to do. Thanks for confirming. :pray: :+1:
