{ “ASSASSIN”, “Luke.wav”,
StylePtr<Layers<RotateColorsX<Variation,DeepSkyBlue>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ “ASSASSIN”, “Order66.wav”,
StylePtr<Layers<
HumpFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>,50>,
//Green humpflicker
AlphaL<Stripes<2500,-2750,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<25,60,0>>,Pulsing<RotateColorsX<Variation,Rgb<0,30,0>>,Black,800>>,SwingSpeed<375>>,
//Swing effect, rippling green
LockupTrL<Layers<
AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup
//Responsive lightning block
AlphaL<RotateColorsX<Variation,Rgb16<21301,65535,0>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1000>,Int<3000>>,Int<-4000>>>,
//Sparking emitter flare
ResponsiveStabL,
//Responsive stab
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb16<38402,65535,3934>>,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<38402,65535,3934>>,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<500>>,EFFECT_IGNITION>,
//Unstable ignition
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb16<54757,65535,0>>>,TrFade<1000>>,EFFECT_RETRACTION>,
//Bright retraction
//Drag
//Responsive melt
//Power save, if using fett263’s prop file hold Aux and click PWR while ON (pointing up) to dim blade in 25% increments.
InOutTrL<TrWipeSparkTip<White,250>,TrWipeInSparkTip<White,656>>,
//Spark tip ignition and retraction
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>
//On demand battery level, if using fett263’s prop file Hold AUX and click PWR while OFF, the battery level is represented by the location on the blade; tip = full, hilt = low and color; green = full, yellow = half, red = low
{“CODA”, “Luke.wav”,
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{“NOBLE”, “Luke.wav”,
StylePtr<Layers<StripesX<Sin<Int<12>,Int<3000>,Int<7000>>,Scale<SwingSpeed<100>,Int<75>,Int<125>>,StripesX<Sin<Int<10>,Int<1000>,Int<3000>>,Scale<SwingSpeed<100>,Int<75>,Int<100>>,Pulsing<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,20>>,1200>,Mix<SwingSpeed<200>,RotateColorsX<Variation,Rgb<0,0,120>>,Black>>,RotateColorsX<Variation,Rgb<0,0,60>>,Pulsing<RotateColorsX<Variation,Rgb<0,0,50>>,StripesX<Sin<Int<10>,Int<2000>,Int<3000>>,Sin<Int<10>,Int<75>,Int<100>>,RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,96>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<0,0,128>>,RotateColorsX<Variation,Rgb<0,0,5>>,3000>>,AlphaL<StyleFire<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,2>>,0,1,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<0,0,25>>,Int<10000>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{“ANALOG”, “Order66.wav”,
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Rgb16<0,38402,65535>>,RotateColorsX<Variation,Rgb<0,85,200>>>,
//Ice blue audioflicker
AlphaL<RotateColorsX<Variation,Rgb16<882,65535,31206>>,SwingSpeed<500>>,
//Bright cyan color swing
AlphaL<Stripes<2500,-4000,RotateColorsX<Variation,Rgb16<0,38402,65535>>,RotateColorsX<Variation,Rgb<0,26,60>>,Pulsing<RotateColorsX<Variation,Rgb<0,13,30>>,Black,800>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,
//Hard swing ripple effect
LockupTrL<Layers<
AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<600>,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<1000>>,Stripes<1500,2000,RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb16<0,65535,30086>>>,Stripes<1500,-2500,RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb16<0,65535,30086>>>>,Int<18000>>,TrFade<800>,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<1000>>,Stripes<1500,1000,RotateColorsX<Variation,Rgb16<1514,65535,52727>>,RotateColorsX<Variation,Rgb16<3934,65535,38402>>>,Stripes<1500,-1250,RotateColorsX<Variation,Rgb16<1514,65535,52727>>,RotateColorsX<Variation,Rgb16<3934,65535,38402>>>>,Int<18000>>,TrFade<1100>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup with click calibration effect
//AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<2100>>,SaberBase::LOCKUP_NORMAL>,
//Alternate lockup ending with white fade out, replace the second AlphaL line above (ending in LOCKUP_NORMAL)
AlphaL<RotateColorsX<Variation,Rgb16<0,65535,30086>>,SmoothStep<Scale<SlowNoise<Int<2300>>,Int<1200>,Int<4500>>,Int<-4000>>>,
ResponsiveStabL,
//Responsive stab
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<1000>>,EFFECT_IGNITION>,
//Bright HumpFlicker ignition effect
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<90,180,255>>,40>,TrFade<1200>>,EFFECT_RETRACTION>,
//Bright HumpFlicker retraction effect
//Drag
//Responsive melt
InOutTrL<TrConcat<TrWipe<200>,AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,TrWipe<100>,Black,TrBoing<550,2>>,TrColorCycle<790>>,
//Glitch out ignition and cycle down retraction
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Rgb16<0,38402,65535>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2200>>,Int<1500>,Int<5000>>,Int<-4000>>>,TrFade<1400>,AlphaL<RotateColorsX<Variation,Rgb16<0,11150,20996>>,Bump<Int<0>,Int<10000>>>,TrFade<1500>,AlphaL<Rgb16<20393,20393,20393>,Bump<Int<0>,Int<7000>>>,TrFade<2100>>,EFFECT_RETRACTION>,
//Retraction cool down effect
TransitionEffectL<TrConcat<TrFade<100>,AlphaL<Pulsing<Rgb<120,120,165>,Rgb<50,50,80>,500>,Bump<Int<0>,Int<6000>>>,TrBoing<600,9>>,EFFECT_PREON>
//Clickity preon
{“DEADLINK”, “Luke.wav”,
StylePtr<Layers<
HumpFlicker<RotateColorsX<Variation,Magenta>,RotateColorsX<Variation,Rgb<150,0,150>>,50>,
//Magenta HumpFlicker
AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Rgb16<12482,0,18076>>,Pulsing<RotateColorsX<Variation,Rgb<10,0,26>>,Black,800>>,SwingSpeed<350>>,
//Ripple swing effect
//AlphaL<AudioFlickerL<Stripes<2500,-3000,RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Rgb16<12482,0,18076>>,Pulsing<RotateColorsX<Variation,Rgb<10,0,26>>,Black,800>>>,SwingSpeed<300>>,
//Alternate audioflicker ripple swing effect
LockupTrL<Layers<
AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup
AlphaL<RotateColorsX<Variation,Rgb16<33124,0,65535>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1000>,Int<3500>>,Int<-4000>>>,
ResponsiveStabL,
//Responsive stab
ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Responsive clash
TransitionEffectL<TrConcat<TrDelay<875>,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<160,0,255>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<21,0,52>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<160,0,255>>,RotateColorsX<Variation,Rgb<21,0,52>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<42,0,105>>,RotateColorsX<Variation,Rgb<21,0,52>>>>,TrFade<250>,HumpFlicker<RotateColorsX<Variation,Magenta>,RotateColorsX<Variation,Rgb<80,0,80>>,50>,TrFade<400>,Stripes<3000,-3500,RotateColorsX<Variation,DeepPink>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<21,0,52>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<160,0,255>>,RotateColorsX<Variation,Rgb<21,0,52>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<42,0,105>>,RotateColorsX<Variation,Rgb<21,0,52>>>>,TrFade<1500>>,EFFECT_IGNITION>,
//Unstable ignition effect
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<180,60,255>>,40>,TrFade<2000>>,EFFECT_RETRACTION>,
//Drag
//Responsive melt
InOutTrL<TrConcat<TrWipeIn<200>,RandomBlink<30000,RotateColorsX<Variation,Rgb16<65535,13655,65535>>>,TrWipeIn<200>,Mix<SmoothStep<Scale<SlowNoise<Int<30000>>,Int<1000>,Int<6000>>,Int<-3000>>,Black,RotateColorsX<Variation,Rgb16<65535,13655,65535>>>,TrDelay<400>,Mix<SmoothStep<Int<4000>,Int<-3000>>,Black,White>,TrWipe<175>>,TrColorCycle<2000>>,
//Lightning strike ignition, cycle down retraction
{ “SENATE”, “Senate.wav”,
StylePtr<InOutTr<Blast<BlastFadeout<LocalizedClash<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<Lockup<Mix<SwingSpeed<500>,AudioFlicker<Gradient<Gradient<BrownNoiseFlicker<Black,Orange,400>,Red>,Red,Red,Red,Red,Red,Red,Red>,Rgb<120,0,0>>,Gradient<BrownNoiseFlicker<Black,DarkOrange,400>,BrownNoiseFlicker<Black,Rgb<128,0,0>,400>,BrownNoiseFlicker<Black,Rgb<128,0,0>,400>,BrownNoiseFlicker<Black,Rgb<128,0,0>,400>>>,Pulsing<Gradient<Strobe<Black,BrownNoiseFlicker<SteelBlue,LightPink,400>,40,90>,RandomFlicker<Red,Rgb<150,20,40>>,Strobe<White,BrownNoiseFlicker<Red,White,100>,50,1>,Red,Red>,Gradient<Strobe<Black,BrownNoiseFlicker<SteelBlue,LightPink,400>,40,90>,RandomFlicker<Red,Magenta>,Strobe<White,BrownNoiseFlicker<Red,White,100>,50,1>,RandomFlicker<Magenta,Red>,RandomFlicker<Red,Black>,RandomFlicker<Red,DarkOrange>>,3500>,RandomPerLEDFlicker<Red,White>>,White,TrWipeIn<50>,TrSmoothFade<50>,EFFECT_DRAG_END>,Gradient<Orange,Orange,White>,TrSmoothFade<50>,TrWipeIn<50>,EFFECT_DRAG_BEGIN>,Gradient<White,DeepSkyBlue,LightPink,DeepSkyBlue,White>,TrJoinR<TrWipe<200>,TrWipeIn<200>>,TrSmoothFade<300>,EFFECT_LOCKUP_END>,White,TrBoing<300,2>,TrFade<100>,EFFECT_LOCKUP_BEGIN>,BrownNoiseFlicker<White,DarkOrange,400>,100,75>,Rgb<120,0,0>>,White,200,200>,TrConcat<TrColorCycle<80,-400,-1000>,White,TrWipeIn<50>,Black,TrDelay<450>,Strobe<Black,White,45,60>,TrJoinR<TrSmoothFade<190>,TrWipe<200>>>,TrConcat<TrInstant,White,TrJoin<TrJoin<TrJoin<TrColorCycle<2050,-1500,-1>,TrBoing<2050,15>>,TrBoing<2050,18>>,TrSmoothFade<2050>>>>>(),
{ “motherfucker”, “mf.wav”,
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<48,0,105>>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
