I am noticing that when switching alt folders containing smoothswing files, the change is not instantaneous due to the way new swing pairs are chosen.
If I follow correctly, hybrid_font updates current_alternative right away and restarts hum, so that changes just fine. But smooth_swing_v2 keeps the two swing loop players running and only re-picks/restarts when swinging is slow enough, plus it has a 1-second anti-repick guard. So during continuous motion, you can stay on old swing loops for a while even though alt already changed.
Adding an SB_EFFECT() override in smooth_swingv2 like this takes care of the issue
void SB_Effect(EffectType effect, EffectLocation location) override {
delegate_->SB_Effect(effect, location);
if (effect == EFFECT_ALT_SOUND && on_) {
A.Stop();
B.Stop();
last_random_ = 0;
state_ = SwingState::OFF;
PickRandomSwing();
Does this look ok, or might it cause a problem elsewhere that I’m not considering?
