I’ve always ignored this part of InOutTrL and probably still will but still curious as to what it does? I’m assuming a one or zero goes here, but how is disabling a thing?
It ties into the logic that disables the power to the blade.
When the blade is disabled, it turns off the power and stops running the style until you ignite the blade again. When a ALLOW_DISABLE is true, it allows this to happen after retraction. (If it is the top layer.). Normally it’s fine to leave it alone unless you have some unusual retraction logic.
